bigboi146
Multi Tasking
bigboi146's Avatar
05.31.2010, 11:22 PM
Wow that's an awesome truck... Good job
Byte
06.02.2010, 12:05 PM
Thank you!
The weather is getting better over here, so soon I'll post a vid of the LST1.5 :)
blueb8llz
06.04.2010, 02:08 AM
beautiful truck you got there. top 5 lst conversions thats for sure.
what springs are you using and shock wt. oil?
Byte
06.06.2010, 07:18 AM
I'm using these springs: Click!
I don't know what shock oil I'm using as I never refilled the shocks. (Probably the stock oil)
06.06.2010, 09:15 AM
Beautiful!! If you can pull 3000 watts and back it up with an eagletree graph I'll eat my shorts
I can't wait for the video, I'm super curious how that beast will jump.
Good job on the build man.
scarletboa
scarletboa's Avatar
06.30.2011, 06:27 PM
it's been a year since any updates....
how has everything held up on the truck? any breakages or electronic failures? any vids?
Dj_Sparky
07.05.2011, 06:16 AM
How much can the BigMaxximums pull anyways? I was looking for 1/5 brushless info, and I came across a German site with 1/5 vehicles (FG, etc.), and they used BigMaxximum. Must be a really low kv or what? Cause I have not seen any 1/5 motors from Plettenberg, and BigMaxximum is supposed to be a 1/8 motor.
07.05.2011, 01:43 PM
The BigMaxximum is only a 1/8 scale motor- 2300kv.
What you probably saw was the Bolido- looks the same as the BM but is much larger:
Bolido is 820kv. You could use the BM in a 1/5 scale I suppose, but only if it was very lightweight, like a stretched 1/8 scale ( Muggy or Savage stretched out to 1/5 scale for example ).
http://www.plettenberg-motoren.com/UK/daten.htm
07.05.2011, 05:54 PM
Wow, somehow I missed this. Thanks for the thanks Byte, the truck turned out very well, and your handmade parts look very nice. You did a great job!
