DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
04.28.2010, 01:04 PM
this is a great idea, and i'm glad Castle is doing this for us. i'm going to order several kits.
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
simplechamp
simplechamp's Avatar
06.05.2010, 09:13 PM
I was just thinking, I wonder if the rotors would work in a Neu 1512 or 1515? Maybe some shimming required but they should be pretty close?
DCastaneda
Speed Addict
DCastaneda's Avatar
06.06.2010, 01:38 AM
Let me know if you do try it because i was wondering the same thing.
Durango DESC410r MMM CC/Neu 1410
B4.1 Worlds MMP RevTech 17.5
SC10 MMP RevTech 17.5
XRAY T2R MMP Duo3 10.5
SC8E MMM CC/Neu 1520 6s
Inferno GT HV- W.I.P. 12s CC HV110
  Send a message via AIM to DCastaneda
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.06.2010, 02:38 AM
Were/Are the CC/Neu motors "based off of" Neu motors, or did Steve Neu actually "help build" or "provide plans for" the motors? I think that would make a big difference.
-Chad
PM ME IF YOU HAVE THE BELOW:
scarletboa
scarletboa's Avatar
06.06.2010, 02:45 AM
the "genuine" neu motors have carbon wrapping on the rotor while castle uses kevlar. i don't think that should make a difference, but if they are willing to change that, maybe they made a few other changes as well. for $25, it probably doesn't hurt to try.
Pdelcast
Pdelcast's Avatar
06.08.2010, 11:29 AM
Steve Neu actually provided all of the design plans (stator, rotor, etc.) for the Castle/Neu motors. Steve also trained our people how to correctly wind the stators for maximum performance, provided all tolerances and specifications, testing requirements, etc.
We decided to use a Kevlar wrap rather than a carbon wrap because of availability of carbon was very bad when we started producing the motors (there was a 52 week lead time on the carbon -- kevlar was available off-the-shelf.) Also, we were able to automate the kevlar wrapping technique.
Carbon is a little stronger than Kevlar, but we were able to pack a little more kevlar with the automated winder. So the strength was on par with the carbon wrap. There is a disadvantage to using Kevlar vrs carbon in that if the wrap fails, carbon just slowly turns to dust (because it pulverizes in the gap between the rotor and stator) where kevlar turns into hard little balls that gums up the gap. We haven't had any issues with this, however, because the epoxy we are using to hold the Kevlar is extremely good... We've only seen a few very minor wrap failures.
The main differences between the Castle/Neu and the Neu motor are: The Castle/Neu uses the Kevlar wrap, the Neu motors use a carbon wrap, the Castle/Nue uses a larger bearing (mainly because of higher side-loads in cars,) the Castle/Neu has closed end-bells (to prevent dirt/dust getting in the motor) and the Castle Neu has a ribbed case (for cooling.) The Castle/Neu motors are made in Castle's facility in China, while the Neu motors are made in Steve's facility in San Diego.
We pay Steve a royalty for every Castle/Neu motor produced. Steve is also working with us on several new designs. Castle is also Neu motor's North American distributor. We have a very good working partnership with Neu motors.
Patrick
Patrick del Castillo
President, Principle Engineer
Pdelcast
Pdelcast's Avatar
06.08.2010, 11:34 AM
Oh, I forgot! There's one other major difference in the Castle/Neu motor -- the Castle/Neu motor uses a keyed shaft and rotor -- mainly because shock loads are so high in cars. That's why you never hear about a Castle/Neu rotor slipping on the shaft.
I have to give credit for this to our engineers in China -- they came up with a very clever solution to key the rotor to the shaft.
simplechamp
06.08.2010, 12:21 PM
Sooooo.... does that mean the CC repair kit rotors could work in a 1515 or 1512 Neu? From what you said it actually sounds like throwing a CC rotor into a Neu would make it better for car applications because of the keyed rotor.
Pdelcast
Pdelcast's Avatar
06.08.2010, 12:43 PM
To be completely honest with you -- I'm not sure. We made some changes to the rotor dimensions to deal with the bigger bearings, and I don't know if our rotor would fit unmodified in a Neu motor.
nuz69
nuz69's Avatar
06.08.2010, 01:27 PM
I think that Neu rotors are a compromise between Y windings and D windings optimisation. NEU-CC rotors are optimized for Y windings.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
06.08.2010, 01:35 PM
True -- but that's just a minor change in the magnet design. Our rotors would work in a D wind motor, but would be slightly less efficient.
simplechamp
06.08.2010, 05:27 PM
Well I'm going to get the 1515 repair kit for my CC/Neu 2200kv, so I'll probably get the 1512 repair kit also, and if the rotor ever goes on my Neu we'll see if the CC rotor will work.
Chadworkz
Chadworkz's Avatar
06.08.2010, 11:58 PM
Awesome, Patrick, thank you for all the information, I really appreciate that!
-Chad
armourbl
06.09.2010, 07:26 PM
That is an awesome price. I have a dead Hacker motor sitting in a box because Hacker wanted $75 for a new rotor. Love that I can rebuild my CC motors for such a great price.
ben
brushlessboy16
brushlessboy16's Avatar
06.09.2010, 07:45 PM
I noticed this when i had to reglue a magnet, very clever using the keyways
