Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Bmr4life
06.10.2010, 06:21 PM
Correct, the X2 truggy has 43/10 differentials.
Oh ok, I choose CRT which must have been X1.
How's this look?
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 14
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 5.65
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.006
Spur/Pinion Ratio: 3.43 : 1
Total Ratio: 14.74286 : 1
Tire Circumference (inches): 17.75 inches (450.85 mm)
Rollout: 1.20:1
Total Motor Speed: 32560 RPM
Vehicle Speed: 37.12 mph (59.63 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
drkdgglr
06.10.2010, 06:23 PM
I believe the X2 truggy has 45/10 diffs.
Bmr4life
06.10.2010, 06:33 PM
I believe you're right. According to the spare parts list, they are 45 tooth bevel gears. That said, the speed calculator doesn't have 45/10 as an option.
06.10.2010, 08:14 PM
If the differential is not listed, simply put the ratio into the box manually. For 45/10 diffs, that would be 4.5
Bmr4life
06.11.2010, 08:48 AM
Jammin X2 CRT
Differential Ratio: 4.5
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 2200
Total Ratio: 15.42857 : 1
Rollout: 1.15:1
Vehicle Speed: 35.47 mph (56.98 km/h)
And how about this one using 6S power with a 2200kv?
Other Ratio: 1
Pinion Tooth Count: 12
Total Voltage: 22.2
Motor KV: 2200
Spur/Pinion Ratio: 4 : 1
Total Ratio: 18 : 1
Rollout: 0.99:1
Total Motor Speed: 48840 RPM
Vehicle Speed: 45.61 mph (73.26 km/h)
George16
Supermaxx
George16's Avatar
06.11.2010, 06:50 PM
I agree. I have the X2 and it has 45/10 diff gears.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Aero
Aero's Avatar
Thumbs up 07.25.2010, 05:37 PM
hiya brian. just had to say its a piece of art, and very useful for may people. the rc calculator. although a connect with progressiveRC and potential other databases, didnt bear fruit, its still a very handy tool, when the head computing seem to go slow.and planning is great...hope to see a new tool emerge from these potentials some day.
Much appreciated that its getting updated now and then, making it responsible work of art..use ful art :)
edit: sorry had an work/art/tool problem, bad english..surprise!
08.02.2010, 03:54 PM
Just trolling my referrer URLs on my server to see where traffic is coming from and noticed a bunch of hits from the Tekin website (towards the bottom on right where it says "How fast will it go").
Metallover
RC-Monster Spudgunner
Metallover's Avatar
08.02.2010, 06:43 PM
Awesome! Congrats Brian! Just goes to show how useful your site is.
ABP
08.08.2010, 07:14 AM
I`m working on a 1/5 on road revo http://www.rc-monster.com/forum/showthread.php?t=27755
Will this work?remember it will be light!
Differential Gear Ratio 2.8 revo
Transmission Gear Ratio 2.5
Other Ratio: 1
Spur Gear tooth count 40
Pinion Gear tooth count 21
Total Voltage 12.6
Motor KD36-74-06XL 2800kv
Tire Diameter 5.1 on road tire
Motor Coil Resistance: 0.0042
Spur/Pinion Ratio: 1.9 : 1
Total Reduction Ratio 13.55311 : 1
Rollout: 1.18:1
Total Motor Speed 33986.4 RPM
Maximum Vehicle Speed 38.05 mph (61.12 km/h)
Effective KV Value: 2800
09.23.2010, 10:03 PM
Update:
I started the process of porting the data from arrays to xml files. What a PITA. So far, the XML files are done, and the code to parse them is done, but I have to adjust a lot on the new pages before the whole site is done.
The current site still uses the old scheme, so nothing changed there yet. However, now there are several XML files available. The information is freely available, but if I start seeing bandwidth limits being hit, I'll have to change that.
The xml files are:
SnoopMaxx
SnoopMaxx's Avatar
09.24.2010, 04:58 PM
Your work is highly appreciated
I use your calculator at least 10-15 times a week if not more
Morten
Morten SnoopMaxx
Never to old to play
c",)
jhautz
jhautz's Avatar
09.24.2010, 10:06 PM
If you made an iphone app I would totally pay for it brian just something to think about
to make it...
or break it...
Silent...But Deadly
09.24.2010, 11:00 PM
Thanks snoop
Jhautz: Sorry. I don't have an iPhone, nor do I plan to ever get one. But don't they render webpages as-is? If so, why is an app needed?
These new XML files make it easier if people want to build such an app, but use a central data store (and without needing server-side coding).
09.24.2010, 11:01 PM
You can actually load the app/site onto the phone - I've done that :)
Currently Active Users Viewing This Thread: 16 (0 members and 16 guests)
