Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
thzero
07.06.2010, 02:33 PM
Ah, ok. Good information, may go that way instead then since I am leary of Integy.
Hmmm i never thought of getting parts for the conversion as a problem, as they are readily available here in the UK. Plus i think its going to be nearly impossible to break the front or rear hubs anyway from the testing i have done so far... I have broken the upper arms multiple times, but i found out that i could use the same parts from the adjustable a arms that HPI sell anyway...
Finnster
KillaHurtz
Finnster's Avatar
07.06.2010, 04:31 PM
I don't know about the rest of the parts, but the Integy rear hubs for the Savage have gotten pretty good reviews from the people here. For $20, I'd go this route for the R hubs.
Bmr4life
07.11.2010, 08:07 PM
You still have this 5B? I just bought one off of ebay and I'm trying to gather as much info as I can. Great build though.
thzero
07.11.2010, 08:53 PM
This isn't a HPI Baja 5B. Rather it is a HPI Savage Flux converted to 5th scale to resemble the Baja 5B.
But yes, its sitting on my floor with a broken axle.
Bmr4life
07.11.2010, 08:54 PM
I know, I just bought a Flux with the TCS kit. Looks just like yours. Just wanted to see how many fellow Flux 5b/5t owners there are.
thzero
07.11.2010, 09:02 PM
Well I got them... with the Tech 5 wheels (glued, not beadlocks) the weight differences are:
ProLine 3.8" Trencher: 15 5/8 oz.
Rear Baja ProLine BowTie: 20 3/4 oz.
Front Baja ProLine BowTie: 16 3/4 oz.
The Tech 5 wheels have basically no offset, the ProLine Baja Desperado wheels have like .5 offset.
Also considering just switching to the Pro-Line Trencher 3.8" All Terrain Front/Rear tires.
Here's a shot showing the difference between rear Baja BowTiie and the 3.8" Trencher.
Jahay
07.13.2010, 09:19 AM
wow the trencher is huge and lighter!!! must be the beadlocks right?
07.13.2010, 09:44 AM
I'll be very interested to see what it looks like with the tires on the car?
thzero
07.13.2010, 11:35 AM
Well the wheel is a bit smaller in diameter, but yes I would say some of it has to do with it being a beadlock. The wheel was also designed for a heavier vehicle than the trencher/tech 5, so its a bit sturdier which typically means more weight.
Sure unsprung weight isn't the best, however to some extent its not the "devil" its made out to be. The 5mm thick stretched TVPs are actually worse for the vehicle than the heavier wheel/tires.
Bmr4life
07.13.2010, 07:31 PM
Question to a fellow 1/5 Flux owner. Does your TCS kit have all of these sideways TVPs stiffeners or did the previous owner of my buggy add those?
I want to mount my batteries inside the chassis, but two of the posts are in the way.
OP, more questions. What foam did you use on your roll bars and how is your battery mounted?
thzero
07.13.2010, 09:05 PM
Yes....came with lots. I only use a few. See my gallery link in original post. Has lots of pictures on how I mounted my batteries internally. I used some rubber from some wire I bought at HomeDepot.
Bmr4life
07.13.2010, 10:26 PM
Thanks. I just took a few of them out including the front diagonal piece. Got it looking like yours. The battery tray should be simple enough to make. I'll be using velcro straps to hold them in place.
Finnster
KillaHurtz
Finnster's Avatar
07.13.2010, 10:30 PM
This thing just rocks
07.13.2010, 10:34 PM
Personally I think the cage is to big and too far fwd... Waiting to see the FLM version...
Bmr4life
07.13.2010, 10:43 PM
The purpose of this kit isn't meant to look like a 5B so the position of the cage doesn't matter. Its probably in the perfect spot for a 5T body.
Only thing I'd like to have different is the position of the transmission and motor. Have those moved further up because mine still pops wheelies on 4s.
Hopefully moving the battery forward into the rails will help.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
