Go Back   RC-Monster Forums > Support Forums > Novak
Which rotor for HV 7.5 in CRT .5 conversion?
simplechamp
simplechamp's Avatar
Which rotor for HV 7.5 in CRT .5 conversion? - 07.11.2010, 08:06 PM
I will be running the HV 7.5 in my CRT .5 on 3S. It will be a bashing vehicle, no racing.
Should I stick with the standard 12.3mm rotor, or would there be any benefit from swapping to the 14mm "tuning" rotor?
I generally run little to no drag brake, and medium to low "punch" control, if that makes any difference.
NovakTwo
Senior Strategist
07.12.2010, 10:17 AM
Because I am not part of Novak's technical support group, I suggest you email tech@teamnovak.com with your question, Our regular CS/Tech Support hours can be located here. Before emailing, take a moment to review the instructions (trouble-shooting guide) originally included with your Novak Item:
Novak Instruction Downloads
Trouble-shooting TeamNovak's One Touch™ Speed Controls
Please make your initial email as detailed as possible. Include:
~ speed control (brand/model)
~ motor (brand/wind)
~ number/type of cells
~ battery, brand (c rating/capacity
~ rotor (old/new)
~ connectors used
~ servo (brand/model)
~ radio system (receiver/transmitter)
~ vehicle & gearing
~ warranty claim?
~ lipo cut-off, on/off
~ any external modules (BEC/brand, Glitch Buster)
~ other important info: water damage, corrosive chemical sprays, excess heat, etc
The more information you provide in your first email, the more quickly tech support can offer you assistance.
Novak Electronics, Inc.
ta_man
07.13.2010, 12:24 AM
I run a 7.5HV on 3S in a CRT.5 and I use the standard 12.3MM rotor. It is plenty fast for a track, it runs cool, and has more than sufficient brakes. I'm using a 14T pinion with the standard size spur on the center diff for use with truck (not buggy) size tires. For bashing you might want to gear up a little. The motor runs cool enough I am sure you could go up a tooth or two from the 14. This is with a Havoc 3S controller, so I'm not fiddling with punch control or drag brake.
simplechamp
07.18.2010, 04:21 PM
Thanks for the info. I think I'll stick with the 12.3mm for now, and maybe next time I have some extra cash I'll get one of the 14mm just to see how it affects the performance.
