Proper switch for brushless
ReV:-O
RC-Monster Carbon Fibre
Proper switch for brushless - 07.24.2010, 07:23 PM
Hey guys,
I've just got rid of the switch on my MMM, since it was causing problems. I was wondering, is there something like a heavy-duty switch that can go between the MMM and lipo, and physically cut the connection between the two? Because that would be ideal.
Does such a thing exist? Solder bullets or deans to each end of the switch, and just slot it in...
tc3_racer_001
tc3_racer_001's Avatar
07.25.2010, 08:15 AM
id be looking at something like a massive relay if you really wanted it to be a switch... it has to carry those hundreds of Amp bursts which you probably require.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
07.25.2010, 08:25 AM
Indeed, it would need to be a massive relay or similar, rated for about 300amps to be on the safe side- good luck fitting that on your truck...
Just unplug the lipo when you are done running or take a break- you wont forget as with the esc turned on the motor will chirp at you every ~10 seconds until you either turn off the esc or unplug the batt.
