Closed Thread
FS: Rampage roller, Neu 2215, 6 Lipos, 200A ESC, Nomadio
KaztheMinotaur
KaztheMinotaur's Avatar
FS: Rampage roller, Neu 2215, 6 Lipos, 200A ESC, Nomadio - 07.29.2010, 04:18 PM
(2) Transmetric 3S 2200mah batteries. I believe they are 20C constant and 30C burst. They are brand new…bench tested for a few seconds. Balance charged then reduced to a storage charge. They have Velcro on one side. 1 ½ pound shipping weight each.
(4) Zippy / Turnigy 5S 30C 5000mah batteries. They are brand new. They were blanace charged once and then discharged to a storage level. They have Velcro on one side. 1 3/4 pound shipping weight each.
Neu 2215 2Y F 8mm 750KV. Brand new…bench tested for a few seconds. There is a flat ground on the shaft. 2 pound shipping weight.
Maytech ESC 200A constant 220 burst 10S Lipo 50V 330uf caps. Includes USB programming connector. More info here: http://maytech.cn/eng/proesc.asp?type=6 Brand new…bench tested. 1 ½ pound shipping.
Nomadio React 2.4 ghz radio. 4 channels. Includes receiver, temp guage, RX activated micro switch, and (3) TX batteries. Good shape. 2 ½ pound shipping weight.
RedCat Racing Rampage. This is an original version with the upgrade kit. I was planning a brushless conversion but I’ve decided to get out of the hobby for a while. 12T 8mm shaft pinion. 40T spur. Bow-Tie tires with Dark Soul adapters all around. Disc brakes on the front. They need some tweaking yet. The shocks are upgraded to Baja VVC. I used the HS5945MG servo for throttle and was going to use it for brakes. Scanner RC HDS9960 steering servo….starting to wear a bit. HS805BB servo and the stock servo are included. Body is included…OK shape…melted a bit on the side from the pipe. Includes roll cage, radio box, extra arms, bumpers, original bevel gears and tons of extra parts. I still have the fuel tank, line, gear plates, and clutch bell…if you are interested in turning it back into gas let me know and I will include them. Please ask questions . Shipping will probably be around 30 pounds but I will help out a little.
I will ship anywhere but won't make false statements on a customs form.
Closed Thread
