Maxxrickard
Maxxrickard's Avatar
08.25.2010, 04:23 PM
The ring gear to tje right in the front. But in the rear to? Or should I have it to the left?
SWEDISH FLM MAXX 5s MMM2200
Maxxrickard
08.26.2010, 06:54 AM
like this:
Manne
08.26.2010, 11:35 AM
Or the otherway... both ways work:) The important thing is that they arent mounted at the same way. If the truck moves backward when applying throttle, just change any two of the three motor wires.
08.26.2010, 12:13 PM
Yep & yep, thats the idea
Maxxrickard
09.11.2010, 01:51 PM
its time to start the winterproject.
two big changes. monster mike CD mount with spiderdiff will be installed in the truck and a UE MONOBLOCK.
YEAAAAAAAAAA
thank you UE robin.
still looking for titanium skids...
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
09.17.2010, 12:50 PM
Have a look at this - "T-maxx Supermaxx Hardcore Titanium Skids f&r Rare!" You will have to do some searching around to find these things...
Alien
Maxxrickard
09.17.2010, 01:21 PM
Yes. I have done My research...
I set of NEW HCR skids are shipped to me.
Thanks Rivermaxx.
Project:
-Mike CD mount with spiderdiff
-UE monoblock
-HCR skids
ANGRY-ALIEN
09.17.2010, 02:21 PM
That's great.... let's see it mounted when you receive it.
Maxxrickard
09.27.2010, 12:55 PM
I hava change My name...
Maxxrickard, same as i have in Sweden and
in the UE forum
Maxxrickard
10.03.2010, 12:43 PM
new diffs. HB PRO
skidplates, some better than other...
3 rear 2 front
1. broken used FLM
2. new ACNC
3. Hardcore racing i titanium
4. NEW FLM
5. Hardcore racing i titanium
mono. have to use my dremel to make it fit.but where do i dremel?inside or outside?
10.03.2010, 04:12 PM
I'd remove the material from where I've highlighted in red- looks like you wont need to remove much at all- snug fit is better than a loose one :lol: :wink: :whistle:
Those HCR skids are awesome- they will bend if you crash into something hard enough, but it takes alot of force to bend them, and to bend them back too- might wanna pickup a couple a RPM wear plates for the front and rear skids too, they will spare the skids from alot of scratches :yes:
Maxxrickard
10.03.2010, 04:49 PM
I have rpm skids too.
The place you mark is not the problem. The problem is the upside, the mono is little to wide to fit the
Chassi.
ANGRY-ALIEN
10.03.2010, 05:15 PM
looking good man.. you won't be disappointed with those hrc skids..
10.03.2010, 09:26 PM
Chassi.
Not sure how/ where you mean exactly?
I have seen people dremel the monoblock to make it fit the FLM chassis before though, Im sure you'll figure it out- dont worry too much about trimming stuff to make them fit, lifes too short- mod it & get bashing
Maxxrickard
10.12.2010, 10:59 AM
Hmmm
I have start My CD project. Ordinary maxx center shafts is little to short. I need ~85 mm long shaft in the front. Amy idee witch brand that makes good quality?
Pictures will come.
