Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
10.08.2010, 09:41 AM
Unless someone posts or I otherwise am sure of the values, they don't get entered.
thzero
10.08.2010, 10:10 AM
Associated RC8T is 43/10 with a center diff (1/1 tranny).
Associated RC8B is 43/13 with a center diff (1/1 tranny).
SC8 is 43/10 with a with a center diff (1/1 tranny).
Associated SC10 is a 2.6 gearbox same as the RC10T/etc.
Losi XXX-T is 2.43.
10.08.2010, 10:27 AM
Thanks for that info!
I use gear tooth counts, not ratios (decreases rounding errors when calculating), so what gear tooth counts make up the XXX-T? I assume since the SC10 has the same ratio as the RC10T that the gears are the same...
thzero
10.08.2010, 10:54 AM
No idea; double checked the Losi documentation and they don't list the gear tooth counts for the three internal gears. Next time I pull it apart I'll have to remember to count them.
10.08.2010, 01:39 PM
I added the Associated RC8T, RC8B, SC8, and SC10 trans and diff data. Let me know when/if you get the XXX-T data...
thzero
10.08.2010, 01:54 PM
Ok, sent an email to Losi, see if I get a response (hahaha).
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
10.10.2010, 01:03 PM
Losi XXX-T is 2.43.
the rc8b ratio is incorrect. it should read the same as the truggy.
here's the info from team associated:
http://teamassociated.com/cars_and_t.../Factory_Team/
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
10.10.2010, 04:27 PM
The page you linked is for the RC8Be electric version. I think he is referring to the nitro version of the RC8B. I don't know if it makes any difference...
DwightSchrute
10.10.2010, 05:31 PM
It's the same through out all of the 1/8 vehicles. i've got both of them.
here's the info from the nitro version as well:
•4.30:1 ratio gearboxes for maximum punch
RC8B Factory Team (nitro version)
Features
•Pre-assembled shocks, diffs, and turnbuckles with Factory Team shock and diff fluids included
•Factory Team 16mm Big Bore threaded, hard-anodized shocks feature heavy-duty 4mm TiN coated stainless steel shock shafts for maximum smoothness
•New 5mm 7075 blue aluminum shock towers allow the driver to stand the shock angle up for a more aggressive suspension
•Optimized front upper camber link bushings allow for more tuning options and are easier to adjust and maintain
•7075 blue aluminum suspension mounts front and rear, with inserts to allow easy and quick adjustment of rear toe-in, rear anti-squat, and front kick-up
•# Optimized steering geometry for more consistency and reduced bump steer
•Updated wing mount with additional clearance for 16mm shocks
•Molded composite radio tray includes optional forward placement battery box for increased steering
•Molded composite front and rear chassis braces
•Tough steel-alloy shock stand-offs
•Factory Team 83mm big wheels included
•Machined aluminum racing clutch shoes
•Lightweight engine mounts
•Factory Team 7075 blue aluminum one-piece top plate
•Light-weight 3mm hard-anodized chassis
•Heatsink brake discs with "FFC" Free Float Caliper brake system eliminates the possibility of unwanted brake drag while on throttle
•Two-piece split-center diff mount allows quick and easy access to the center diff
•Caster blocks adjust 14, 16, or 18 degrees with molded inserts
•3.5mm light CVA drivetrain with full ball bearings
•Rear molded CVA boots to keep dirt and mud out of rear joints
•Blue aluminum hexes and nylon locking wheel nuts
10.14.2010, 11:48 AM
Update:
Now that much of the data is in XML form, I have created several pages to manage the data via the web interface. However, I need a few testers to make sure things work right. I did my own testing, but it's always better to have more than one set of eyes.
Ideally, I plan to have a few people (mods, long-time reputable members) with the ability to edit/add data as needed, but first need to make sure everything works.
I only need a few people as of right now, so if you don't mind helping, send me a PM and I'll provide the link and login credentials.
slimthelineman
slimthelineman's Avatar
10.14.2010, 01:46 PM
when i ran a xxx-t back in the day the tranny was a 2.56:1 don't know if that helps.
10.18.2010, 08:27 PM
Update:
I reworked the R/C Calc site so it will fit nicely in a smaller area primarily so it can be used as a Facebook application. I know some of you won't like the new layout, but the developer gets to decide what's best . Besides, what do you expect for free?
However, I can't submit it to the applications directory until it gets "5 total users or 10 active monthly users". Don't ask why because I don't know. Makes no sense to me since I would think you'd need to submit it to get a user base. Apparently, they do this to discourage the use of applications that require user authentication. But since my app doesn't require it, you'd think it would just publish?
Anyway, if any of you are a registered facebook user, could you do me a favor and go to the application page and "like" it? Not sure if it will help though, but it can't hurt. If that doesn't do it, I'll have to trawl through all of their API documentation, 99.9% of which does not apply, but whatever.
Here's the link since it won't even turn up in a search: http://www.facebook.com/apps/applica...14159475311275
10.18.2010, 09:50 PM
Liked.
The new layout is actually pretty good- no more difficult to navigate, though the right to left switch when using each separate tool is a little odd at first.
You know, the only thing missing is some nice big logo or image on the home page of the r/c calc page/site- big white expanse with a link at the top looks rather empty- needs some epic picture or logo etc..
jhautz
jhautz's Avatar
10.18.2010, 10:17 PM
Update:
Wait!!!! So I gotta get a facebook account to use your calc now?? Don't like that idea. Ive got no use for facebook, but I use your calc page all the time. Could be the mose usefull piece of software ever written.
to make it...
or break it...
Silent...But Deadly
10.18.2010, 10:33 PM
Liked.
I thought about putting a logo somewhere to make it look better, but A) I don't have a logo, and B) I don't like to add stuff that doesn't directly improve usability. Glad you like it though. I thought it was a bit "plain".
lol, no no, it's still available in the same old location. As a matter of fact, the version on facebook is simply an iframe that contains the site. I just wanted to add more exposure.
Currently Active Users Viewing This Thread: 38 (0 members and 38 guests)
