I did a conversion on the detta st, and made it an SC using the Phatbodies SC body.
Im running steel front and rear cvds, balls diffs with steel gears from thetoyz.com, 3s and the CM26 4600kv motor, like everyone else, its crazy fast on 3s, 2s for the track...
I already had 6 2200mah 2s packs when I got my ST, found out how much shorter it was than the SC real quick when I tried to put a pack in it. DOH.
I just bought another SC chassis and swapped everything over, made the ST body fit, looks a little goofy at the back but works fine. Gotta look for a better fitting body now ?
