Anyone with Mikes CRT.5 chassis kit, Whats the wheelbase? -
01.19.2011, 06:37 PM
I contacted Ofna about doing a truggy like the hyper 10tt, They say they don't plan to do one. So i want to make one of my own, The plan is to either use the hyper 10tt upgrade chassis and shafts (If the .5 parts will fit), Or use Mikes conversion if its long enough. Hence my main question, Those who have Mikes chassis, Whats the wheelbase? It needs to be 11.0 inches (hyper 10tt) to 11.75 inches(Losi Ten T) I also plan to use Mikes Long arm conversion as well, to open up wheel options as well. Probably use T4 associated arms, on that note, Has anyone tryed the associated QC system on a CRT'5? might be an option
as always, thanks for any info given
01.19.2011, 10:27 PM
Just measure mine, it's just under 11", that was measures from the center of each wheel.
I like the looks of the Hyper 10tt and I was going to get one but I got a real good deal on this CRT.5 and couldn't pass it up.
Good luck,
Nick
Site Owner
01.19.2011, 10:39 PM
Our ext. crt.5 has about an 11" wheelbase(perhaps 10 7/8" or 15/16" depending on your toe adjustment) - just about identical size as the mini Hyper truggy. It was a bit before its time!
01.19.2011, 10:46 PM
Thanks guys, This helps. Nothing against the hyper, i just liked my CRT.5 better. My plan was to get one, convert it and leave it alone, but with the 1/10 truggy coming out now, I want one as well, so i guess i'll need two now.
once again thanks
got to figure our how to setup the QC setup for the truggy
01.20.2011, 05:14 AM
sorry to jump in on this thread, but how do the HyperSC10 and hyperTT compare in length?
Thanks
01.20.2011, 12:15 PM
Thanks
no problem, the hyper sc and scrt are 12.75" while the 10tt is 11.0"
01.20.2011, 12:39 PM
awesome, thanks alot.
My have to do a crt to 10th truggy using the monster scrt chassis :)
would be awesome...
or would it look too long....
01.20.2011, 04:18 PM
Depends on what you are aiming for, the scrt/hypersc and rc-m sc are the same wheelbase as the old revo2.5 so any body for them might fit. Might be wise to use the rc-m arms as well for a wider truck, I think this body would be perfect for what you want to run,
http://www.xtremercracing.com/Store_...ue&SnipID=5259
tucks in tight on most chassis's and fits the wheelbase
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
