bigbadtaz
bigbadtaz's Avatar
02.04.2011, 06:36 PM
i hope you got a slipper clutch on that thing a. i have a mgt i did and remove the slipper and a kept chewing up the gears a had a hobby wing 2150 on it on a 4s
Krawlin
Got brushless?
Krawlin's Avatar
02.04.2011, 09:30 PM
Cool conversion, while I'm not a fan of the stock transmission, you have all logical reasons for keeping the trans. I must have missed it, have you said whether you are using 2 smaller batteries or 1 large battery? I know that on the left side you can fit a pack with the stock trans still in place, but the right side will be a pretty tight squeeze with the pinion/spur in the way, unless you stand the right side pack on its side. If you go the single left side battery route though, I would suggest a Gorilla Maxx battery strap, I use them on mine and they work great. No fussing with trays, just 2 holes, and a simple velcro strap.
The main 3 reasons I got rid of it in my MGT is that it takes up a large amount of space, it's rather heavy, and I got tired of constant wheelies back when I had my E-Maxx, when I switched to a center diff in it, I knew I wanted the same setup in my MGT. I love the handling benefits of a center diff, plus the extra space on the chassis for other components. And with 100K diff fluid unloading of 1 end of the truck isn't really an issue, as I rarely drive on obstacle where the front or rear of the truck sees a bind and unloads the center diff to 1 end.
Back on the battery issue though.... I have seen on URC where some guy used Savage Flux battery boxes, only issue I have with that is their length, and the way he mounted them, they still sit pretty far out like the stock mud guards. I am planning on milling slots on both sides of my chassis to accept the Flux trays, which will keep them more towards the center line of the truck, and improve the looks (be able to run a narrower body). I would like to attempt to shorten the Flux trays but I'm afraid it would ruin them. However, in your case, if you were to machine the chassis to move the steering servo inward and ditch both mud guards, and then use flux trays with the stock mounting, which would set them just to the edges of the chassis, you could run dual batteries, have no worries about the spur guard being in the way, and have even weight balance. I would do it this way myself (but with my center diff), but I want to bring as much weight toward the center of the truck as I possible can, so putting them right at the edge of the chassis isn't my first choice, as it isn't much better than putting them flat on the mud guards, but in your case it would be perfect because the spur is in the way of doing that.
Monster GT Conversion
Video Upload......
10kman
10kman's Avatar
Video Upload...... - 02.06.2011, 02:26 PM
Sorry for the bad quality, it's from my phone, one-handed driving.
But, BOO YA, standing backflips even with the wheelie bar getting in the way. I wasn't expecting that, so that's just icing on the cake.
I saw a question about my battery setup, I'm using one 4s2p pack, I have my ESC mounted on the left side for now. I may move it and move the battery to the left, I ripped a velcro strap while out today and the battery was flopping around, which obviously isn't great. No big deal, just a tweak I need to make.
Truck is awesome though, no punch control or throttle curve adjustments made, it's a stock ESC setup.
Enjoy, my apologies again for the bad quality.
http://www.youtube.com/watch?v=pPgHpdo6n-I
10k
Scott_T
02.07.2011, 09:02 PM
Very cool 10K,
My boys and I gathered around to watch an MGT back flipping. I am so jealous, but you really gave me hope I could get this done and it would be cool without the center diff...
Thanks,
Scott
10kman
10kman's Avatar
02.07.2011, 09:44 PM
Awesome Scott! Glad you have some inspiration. Remember this is all on a 4s LiPo, you can probably get nuts if you mount up some bigger packs. I didn't think it would flip like that with the pack strapped to the front, I was hoping it would keep the front-end down. Yeah right!
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
02.08.2011, 07:59 PM
Looking Good 10k! wheelie machine...
I have to disagree with Revonut. A CD actually makes these overpowered MT hande the Brushless power alot better. (can keep the front wheels on the ground). To each his own, But I thought I should add this... Just because you got a CD doesnt make it just a racer... Just not a Crawler...
As you can tell I swapped to a CD as well... (100k oil though)
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
