Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
02.13.2011, 06:58 AM
I think the FG VW bug body with full fenders is really cool, always wanted to have one. That and Exceed has a '48 chevy truck body they put on their Rampage clone that I really want but can't seem to find for sale separately from the truck.
MCD has a SC style body
http://www.largescalerc.com/mcdbaja1...bodyshell.aspx
Or if you want something really different MCD also has one of those Euro transporter van bodies. Its meant for onroad, but it could be cool, in a 1/5 scale "Lunchbox" kinda way!
http://www.largescalerc.com/mcdvwtra...bodyshell.aspx
Speaking of onroad theres a Nascar body for MCD/FG cars too.
http://www.largescalerc.com/StockCar...n-RoadCar.aspx
Thanks for the input - I like the FG beetle as well, but I was also giving some thought to the FG Jeep - we'll see.
And for the on-road stuff, maybe that will have to wait till my next build - who knows?
Overdriven
Destroyer of Tires
Overdriven's Avatar
02.13.2011, 10:46 AM
Doh I forgot to put the jeep in my post. Knew I was forgetting something. Only bad thing about the beetle with full fenders is finding the right size tires and keeping them off the fenders when the suspension is compressed. I'm pretty picky about the bottom of the body covering the chassis though, making that part a little harder. FYI, the width is just about right for a monster truck suspension with standard offset wheels.
brian015
brian015's Avatar
02.13.2011, 08:10 PM
I'm really starting to like the FG Jeep body after looking at more pics:
The FG truck has a wheelbase of 475mm (18.7in):
FG Monster Jeep
Looking at this pic, the Jeep Body seems to have a slightly shorter wheelbase than the truck itself:
So I'm thinking that I could build my truck an inch shorter - 17.5 in wheelbase - and have it fit nicely under that body. But I'm still open to other ideas.
brian015
brian015's Avatar
02.14.2011, 12:07 PM
Well, unfortunately it looks like these FG Jeep bodies are currently unavailable from US suppliers. I sent out some emails over the weekend, but am being told that they're not being supplied right now. So unless something turns up, I'll probably have to go in another direction.
Jahay
02.15.2011, 08:18 PM
Brian, where about did you get your axle extenders from? are they a 23mm hex as well???
brian015
brian015's Avatar
02.15.2011, 08:25 PM
From Trevor's (can't beat the price on these):
http://cgi.ebay.com/Pro-Line-23mm-He...item230e21fdc9
yep - 23mm hex
Edit: and they have held up great - no problems with these at all.
Jahay
02.15.2011, 08:39 PM
THANKS A LOT BUD! THAT IS A CRAZY CHEAP PRICE!!!
As i am thinking about running baja rear tyres all around, i was thinking of just running the extenders on teh rear like i did with my XL Savage axles... gave good turn in and drifiting ability as it had a slightly wider track in the rear... Ill buy 4 any way at that price just in case... have you broken them yet with any of your jumps? they must obviously taking their toll on your bearings right?
brian015
brian015's Avatar
02.15.2011, 09:07 PM
No problems with these extenders at all - and I've done plenty of cartwheels. But you see why I've added a bearing to each of my carriers to help support the axles.
I run these all the way around for the greater stability while driving. I have to really try to make this thing roll over. My rear wheels are wider and slightly offset so the rear is slightly wider than the front.
v8hatch
v8hatch's Avatar
02.15.2011, 09:36 PM
Mate you have done some great things to this buggy along the way, i like the idea of the 23mm hex and using the Baja wheels did you ever run it with the losi wheels?
brian015
brian015's Avatar
02.15.2011, 10:06 PM
Thanks, I decided pretty early on in the build that I really liked the look and size of the baja wheels, so I've only used them. I got around to weighing them recently and the fronts are each 460g and the rears 560g - so they definitely add some weight to the buggy.
v8hatch
v8hatch's Avatar
02.15.2011, 11:23 PM
WOW they sure do, i have some Baja wheels just not sure if i want to use them because of the wieght and whats invovled in fitting them, but it looks like from what you have done it's not that hard.
Jahay
02.16.2011, 06:51 AM
WOW THAT IS A LOT OF ADDED WEIGHT!
i bet that weight is because of the beadlock wheels and not the tyres them selves! HMMMM there must be other light normal style glue wheels we can use that accept the baja tyre???
you havent weighed the wheels and tyres separetly by any chance have you??
THat is a lot more weight than i really want to add honestly... My alloy spi and badland tyres weigh 310grams per corner... i wouldnt mind going to 450grams per corner with the added power... but 560g!!!!!! nearly double!!! it does look like your truck has no prob pushing the heavy tyres around, but i will really have to think about it... may ask around and see if there are any other normal wheels...
Have you just used the beadlocks to lock the tyre to the wheel??? i was thinking that brushless power would be too much for beadlocks and you would need to glue as well as use the beadlocks to hold the tyre on??? have you had any probs?
brian015
brian015's Avatar
02.16.2011, 08:04 AM
No glue, just the beadlocks - and no problems. We'll see how well they hold up to people running the MMXL/2028 combo, but I've read of no complaints. I'm not sure that the fact that they are beadlocks really adds that much weight to them - they are just very beefy all around. When I had them apart to tape them last summer I should have weighed them, but didn't.
othello
HV basher
02.18.2011, 09:46 PM
@Jahay
You might want to try those Baja wheels then. Glued with no beadlock. Front wheel wheighs 370gr and rear one 475gr. I'm using them also with the afore mentioned 23mm wheel extenders on my Baja/Truggy build.
But i had to shave some plastic off the wheels as the extenders thread is not long enough to securly mount those wheels. Not an optimal solution either if you want proper concentricity.
Without modifications to the wheels it looked that way:
When using those extenders you will have to wrap the hex with some thin Alu foil (brian015 already mentioned that. I cut some strips from a can of coke) otherwise it will look that way:
@brian015
Always red your thread. Good stuff. Good modifications. Did your beadlock wheels fit properly to the extenders?
ID:	9739   Click image for larger version
brian015
brian015's Avatar
02.18.2011, 10:17 PM
othello - thanks for the links to those wheels - I wouldn't mind some lighter ones in the future, too.
The nuts on my wheel extenders do not thread on all the way (as in your pic) - but I crank them down pretty good (with a 23mm socket and a long bar!) and I've never had one come loose on me.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
