radioman193
radioman193's Avatar
03.22.2011, 02:27 PM
i got this in two parts as the first part like a dumb fool i only had a 1 gig card in my camera so this video is short .
a slow down video
and the secont one is about 17 minutes.
it looks like its sitting odd cause a rock was caut under the left rear swing arm .
plus i have found Why it drifts to one side .....
as the front comes off the ground the front tires start ballooning but thay Dont balloon at the same rate so as the front lifts off the ground one of the tires is still in contact with the ground pulling it that direction.
Just Fix It !!!
I have been into electronics for 30+ years
and am a licensed Electronics Technician for over 26 years now.
  Send a message via AIM to radioman193
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.22.2011, 05:39 PM
great vids..
maybe it's drifing to one side..
1) drive cup is loose
2) wheel hex is stripped
3) pin for wheel hex loose or broken
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
aqwut
aqwut's Avatar
03.22.2011, 05:41 PM
instead of using epoxy, you could probably use thermal glue to waterproof the electronic.. but it may take a day or two to settle..
radioman193
03.22.2011, 06:26 PM
I think im going to Lock the center diff.
then i will have more power to the rear when the front lifts and when the front lifts thay will only spin as fast as the rear tires and would stop all the pizza cutters.
Just Fix It !!!
radioman193
03.22.2011, 06:36 PM
Originally Posted by aqwut View Post
great vids..
Thanks
i just cleaned it all up and all is perfect
it Only pulls if one tire on the front is still on the ground then pulls to that side........ if i pull a HARD fast wheelie and get the front tires off the grond fast it is straight as an arrow.
Just Fix It !!!
Overdriven
Destroyer of Tires
Overdriven's Avatar
03.22.2011, 07:30 PM
Some heavier fluid in the front diff will help keep one front tire from unloading and pulling the truck too. Thanks for starting the lively discussion on a topic I started to forget about. Just remember its a forum and true emotions can't be relayed in text easily. Plus these guys like to rough you up a bit, but all in good fun.
radioman193
03.23.2011, 04:17 AM
i will try that first
Just Fix It !!!
radioman193
03.24.2011, 03:09 PM
no Damage and Nice and Clean again......
Just Fix It !!!
radioman193
03.24.2011, 08:37 PM
This thing is the Cat's Meow !!!!
Just Fix It !!!
