What gear ratio should use on XXX-T Matt Francis 1 ?
Quebecois_Sti
What gear ratio should use on XXX-T Matt Francis 1 ? - 03.24.2005, 09:13 AM
Hello,
what gear ratio I should use when I will have my brushless combo ? (MGM Compro 80amp with Feigao 8s) I will use it with 6 cells and sometimes 12 cells and in the future 3s 11.1 LiPo. My gear ratio of my brush setup is 22/86.
thx for help
Olivier Mathieu
legomind@hotmail.com
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.24.2005, 09:29 AM
I usually recomend gearing the 8s similar to a 12 turn motor for the applicable vehicle (starting point). If you go to the 11.1 volt LiPo setup, I would drop a tooth or so as a starting point. You can adjust from here, but this should put you in a safe starting range.
Quebecois_Sti
03.24.2005, 05:35 PM
and for a 12 turn motor what is the gear ratio I dont know... i am currently on a 19T chameleon.
Olivier Mathieu
RC-Monster Mike
Site Owner
03.24.2005, 05:42 PM
Do you have the manual? This information is usually listed in the manual.
Quebecois_Sti
03.25.2005, 11:35 AM
i find it!
it's 15/86 for 11turn and 16/86 for 12turns
thx guys!
Olivier Mathieu
