1/4 rc car project twin brushless motor
corsamegane
1/4 rc car project twin brushless motor - 09.21.2011, 03:26 AM
Hello
This is my first post here and I want to show some virtual images of a project I'm making, is still in the design phase but is basically ready and I can start joining some stuff that I'll need.
I also did a comparison test between the dimensions of my project and an Hpi baja 5b in order to have a better sense of the actual size!
hope you enjoy!
Spec´s
Dimensions
Lenght:1010mm (40 in)
Height: 272mm (10.5 in)
Width: Front 645mm / Rear 640mm (25 in)
Wheelbase: 785mm(31 in)
Ride height: 75mm(3 in)
Weight: 13.5kg (29.7lbs)
Motor and esc spec
twin brushless motor leopard 5692 1000kv
4x lipo 6s 5200mAh total of 20800mAh in paralell
Esc 150A Xerun
transmission and Steering
4-wheel drive
3 differentials
twin servo hitec 805bb 6.0v(24.70 kg-cm)
tyres Ø 195mm, width 110 mm, rims 110mm
http://www.youtube.com/watch?v=RyL_FzJoB3w
brainanator
brainanator's Avatar
09.21.2011, 08:54 AM
nice!!! This should be a fun thread to follow! :)
crazyjr
crazyjr's Avatar
09.21.2011, 06:59 PM
Are you plaanning two esc's? not sure if One to two motors can be done proper. I think you are running both not enough esc and too much battery. Why not slpit the battery and run two esc's? or split the battery and series it to a bigger, stronger esc and better motor for this application? If it were me, I'd split the battery and make a 12s 10,400mah , at least a 200 amp esc (12s capable) and either a plettenberg bolido or a lehner 3080 motor
brian015
brian015's Avatar
09.21.2011, 07:01 PM
Looks like quite a project! I'll be keeping my eye on your progress. Good luck!
What differentials are you using for this?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.21.2011, 07:02 PM
Mamba xl combo, should be capable of putting out plenty of power
corsamegane
09.21.2011, 08:37 PM
hello!
This car will use two xerun esc's and must have a maximum of 6s lipo which is what the esc can handle.
This esc is very good compared to others on the market that cost three times more and does pretty much the same thing. I'd like to use another esc, but still very expensive, it is better to wait a while and then the price of these new esc like mamba will be more accessible
Here is a picture with the two options which can be used to reduce weight or increase autonomy.!
corsamegane
09.21.2011, 10:30 PM
I pretend to use some fg or Carson differentials but I'm researching other alternatives that are more affordable, but it is not easy to find!
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.21.2011, 11:29 PM
Depending on the weight I think you could get away with some 8th scale differentials. The LST2 differentials are extremely tough.
www.cubicle101.com
corsamegane
09.21.2011, 11:51 PM
The differentials coming from 8th scale would suffer because the car will weigh 26lbs to 30 lbs I really have to use 1/5 1/6 diffs as the HPI baja, fg monstertruck or otherwise the motors will break the diffs.
x-y
x-y's Avatar
09.22.2011, 04:53 PM
thats insane man ......... motor = +1800gr ...... battery= +3500g ...... 2esc ...... if you build this provably will destroy many diffs, but will be an epic project...... :D
regards and good luck ..... we waiting notices/photos of the construction :)
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
mothman
09.23.2011, 02:24 AM
You should try the flux diff.. never heard anyone managed to break it yet.
ransom
09.23.2011, 06:04 AM
oh they break all right in stock flux on 6s
not the ring and pinion but have seen
the small bearing break lots - fix is to run vorza plastic cup and bearing
alloy cup snap under that same bearing - same fix
spider gears and shafts break - hb lightning fit and are stronger
output gears snap at the pin cutout - hb lightning fits again
whole front bearing mounts broken right out of the bulkhead - fix is alloy bulkhead
this 1/4 project looks good will be interesting to see how the centre diff handles it
and the weight of the motors and battery s could maybe go forward the more weight to the front the better especially with centre diff
corsamegane
09.23.2011, 08:31 AM
Hello
The diffs that I intend to use are similar to the diffs of the photos, I saw these pictures on the net and you can get an idea of ​​their size,The diffs of the flux are not meant to take on so much weight and on this car(27lbs) I do not believe that the flux diffs could last to long!
About the weight distribution I will try to move forward the lipos 3 inches and the motores 2 inches which is the maximum that can go.
brian015
brian015's Avatar
09.23.2011, 08:50 AM
I agree - you want those big diffs in this car. I've seen that 1/8 scale diffs can hold up in an 18-19lb truck but I wouldn't use them in anything over 20lbs.
-brian
Overdriven
Destroyer of Tires
Overdriven's Avatar
09.23.2011, 08:57 AM
Have you considered the Redcat 1/5 scale diffs? I'd have to assume that they would be less expensive than the FG stuff, but still tough as well. I haven't heard of any failures with them either, other than bearings wearing out which can be fixed with better quality bearings. I agree with Brian though. Certain 1/8 scale diffs are tough and can be made to withstand alot of abuse, but not that much abuse and weight.
