Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
coolhandcountry
coolhandcountry's Avatar
12.05.2011, 01:34 PM
I am curious as to how the beast will turn out as well.
brian015
brian015's Avatar
12.24.2011, 10:57 AM
So, I've been able to make some progress on the truck.
Here's what it currently looks like:
Steering hardware installed:
All shocks mounted with M4 screws and 8mm thick-wall Al tube:
I have a list of things to do over the Christmas holiday when I should have some spare time. I'll post what I get done.
yzinger02
yzinger02's Avatar
12.24.2011, 11:25 AM
Looks good! Ill be really interested to see this thing finished.
brian015
brian015's Avatar
12.24.2011, 08:55 PM
I don't think I mentioned this in this thread, but I built these shocks as I did on my other large scale vehicle (here) and put a thin lexan piece on the shock piston covering 10 of the 24 holes (imitating the traxxas variable damping kit - as originally suggested by mistercrash).
I really like the way this handles on the other truck and am going with 20wt oil all around to start with on this build. I found that this lighter weight oil gives the shocks good rebound with a heavy vehicle, with the lexan covering 10 of the holes allowing the shock to still have good damping when being compressed.
12.26.2011, 11:40 AM
Love the project man, awesome work!
brian015
brian015's Avatar
12.27.2011, 11:14 AM
Thank you.
Here's a little progress. I've been mounting battery trays and installing the front FG bumper that goes with the Hummer body - I still have a couple more support bars to install:
The wheels and tires I bought for this are 5b fronts - Black Desperados and Hostile MX hard compound (with taped pro-line foams). The 5b rears are too wide for what I wanted on this build - so I thought the fronts would be best. They recently came out with MX 5b front tires - which are supposedly the toughest tires around - I like how they look - here is a quick mock-up of one wheel/tire with the body in place:
coolhandcountry
12.27.2011, 12:25 PM
That looks pretty good.
Kind of like the size tires to the body.
Makes it look more scale.
Can't wait to see it further along.
brian015
brian015's Avatar
01.01.2012, 04:50 PM
Thanks, I like the look of the tires with the body, too. I mounted and weighed one of the wheel/tire/foams = 450g
Here's the front bumper mount finished. It seems very solid:
brian015
brian015's Avatar
01.12.2012, 08:23 PM
I'm going to try the EZRun 150A Pro esc in this build and just wired it up to run two 6s packs in parallel:
I strapped it down with a padded Aluminum strip and Al angles front and back to keep it from moving:
Things planned:
I've been working on cutting down some 23mm hex extenders to give the right width for this build.
I'll add a brace from front to rear bulkheads.
I'll need to make body mounts and then I'm planning to add some lexan undertray pieces to extend out from the chassis and attach to the body.
yzinger02
yzinger02's Avatar
01.12.2012, 08:31 PM
Great work, as usual! I haven't really heard any bad things about the ezrun escs in fact i really liked my 80A and id still have it if it didn't get fried in the ocean...
brian015
brian015's Avatar
01.12.2012, 08:40 PM
Good to know. Memo to self: keep trucks out of ocean.
yzinger02
yzinger02's Avatar
01.12.2012, 08:43 PM
Hahaha yeah but the batteries in my tx died and i didn't have the fail safe set so it went full throttle into the ocean after bouncing off a random guy's leg...
brian015
brian015's Avatar
01.12.2012, 08:48 PM
That stinks.
yzinger02
yzinger02's Avatar
01.12.2012, 08:50 PM
Yeah but anyway keep up the good work and it looks like its going to be alot of fun when its done!
brian015
brian015's Avatar
02.18.2012, 12:40 PM
Update:
I installed a 1" - 1/16" thick u-channel between the two bulkhead top plates for added rigidity of the truck - the chassis is flat so it would bend by itself. I'll run some of my wires along the u-channel to keep them out of the way.
I've also cut down some pro-line hex extenders to give the truck the width I want. I wrap the 23mm hexes with Al tape to get it to 24mm for the 1/5 wheels.
I've also changed the color of my 1717
Pics:
