ducati777
02.21.2012, 02:13 PM
Dude my cheapo turnigy charger will do over 9000 packs in parallel.
Yea. That.
Lulz, on a more serious note, I'll look up that 306B, I was thinking i208. I just want a zillion amps at 6s, preferably on a 12 volt supply.
feistyacorn
feistyacorn's Avatar
02.21.2012, 02:48 PM
That would be a 72s pack. You probably meant "in parallel".
Dang, thats what I meant.
Originally Posted by ducati777 View Post
...cheapo turnigy charger...
0.000000001c doesnt count. Also, I guess that I should have specified, rtr out of the box. As it turns out its six 8s packs. http://www.usastore.revolectrix.com/...MPA-XH_Combo_2
I suppose a guy like you that has 9000 packs will need 9000 of these: http://www.usastore.revolectrix.com/...rallel-Adapter
bruce750i
bruce750i's Avatar
02.21.2012, 03:25 PM
feistyacorn or Snellemin: I would like a high power 3s(and up) Non-balanced lipo profile that uses the banana plugs only. Can that happen with the Powerlab 8?
(4 tiny)3s packs for 12s.
I just ordered a para board for the smart ass Powerlab 8 to be happy.
ducati777
02.21.2012, 03:34 PM
lol, I was thinking that too... it might take me over 9000 hours to charge too.
I do like para boards.... just got one.
I've only made up 4 traxxas adapters so far.... but after I find a charger with more amps, I could see charging 6x 3s in parallel.
Good call.
feistyacorn
02.21.2012, 03:37 PM
http://www.revolectrix.com/pl8_specs_tab.htm I think it can only do 2s lipo in the unbalanced mode. I've only used the balance mode, but I'll check the software when I get home.
bruce750i
bruce750i's Avatar
02.21.2012, 03:46 PM
I'm about over it now but wish I knew that before I bought it.
I ordered the software/usb stuff for the PL8 months ago but it got lost in the mail apparently. Thanks for your help let me know what you find out.
x-y
x-y's Avatar
02.22.2012, 01:41 AM
¿saw the new imax b6 ultimate 800w? ........
-Operating voltage range: DC 12.0-18.0 Volt
-Circuit power: Max. Charge power 2x400Watts
Max. Discharge power 2x25Watts
-Charge current range: 0.1-20.0A
-Discharge current range: 0.1-5.0A
-Current drain for balancing Li-Po/Ion/Fe: 300mA/cell
-Li-ion/Fe/Polymer cell count: 1-6cells
-NiCd/NiMH battery cell count: 1-18cells
-Pb battery voltage: 2-20V
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
x-y
x-y's Avatar
02.22.2012, 01:46 AM
feistyacorn
02.22.2012, 04:28 PM
I played with the software some and profile 6 (unbalanced lipo) is locked at a max of 2s. Here is a link to the latest PL8 software (you can test it out without a PL8 connected): http://www.revolectrix.com/new_appli...ftware_v2.html
bruce750i
bruce750i's Avatar
02.23.2012, 12:48 PM
That's a sad and disappointing way to sell balance boards. I couldn't get the PL8 to discharge a slightly over charged lipo (even with the cell taps hooked up). My Hyperion wouldn't do it either though for that matter. I had to go to an A123 discharge mode on the Hyperion. Is 4.31v per cell bad?
Thanks for the link. I'll give it a try.
ducati777
02.23.2012, 01:44 PM
Perhaps I could interest you in a hacked up heat sink with a resistor glued to it?
bruce750i
bruce750i's Avatar
02.23.2012, 02:12 PM
^No thanks, I'll pass.
