othello
HV basher
01.06.2013, 08:40 PM
@big house
i bought some FG 18mm square wheel adapters which are 9,5mm wide (part nummer FG6107 i think). They fit perfectly onto the 1:8 truggy axles as they have a 8mm bore and can be tightened onto the axles with 2 6mm grub screws (i never lost one adapter while driving). You can find square wheel adapters with more width (i chose the narrowest i could find). You only have to make sure they feature a 18mm square and have an 8mm bore (i think 8mm axles are common to most 1:8 truggys or buggys).
I'm using a screw and a washer to keep the wheel onto the wheel adapter as the truggy axle comes with a thread. I realy thought i will loose my wheels while driving but this never happened.
ID:	10581   Click image for larger version
x-y
x-y's Avatar
12.30.2013, 09:09 PM
that car need 1/8 foam tires like "ofna foam tire" ........ the weigh of that foams is only 90gr each tyre+wheel .....
I used many times that foams in "experiments" and if you use a hard compound have a very long life ......
http://www.youtube.com/watch?v=uqPWNlZ5cgQ
SWORKZ BE-1, LEOPARD, HOBBYWING, GENS ACE, SANWA VX, FUTABA 3PL, MBX5R/T, RB5SPSL, FG MONSTER, TC5R, 808E, HYPER8, TF5, ZX5, NANO-TECH, HYPERION, 620DMG, ECO6-10, TEAM-IHOBBIES
