Mr E-Maxx
Mr E-Maxx's Avatar
02.01.2016, 08:01 PM
Hello Guys,
so I made some test runs and I am very happy with this truck. The Sock Oil and Springs are too soft, but I started with 30wt Asso. Now I running 37.5wt with Medium Team C Springs. This is much better but still very soft. So I need some stiffer springs. Maybe Team C rear hard or Hot Bodies rear in orange, red or gold.
I think the new HB orange are very good for a 5.2kg Truck with heavy wheels.
The Diffs fell good with 7k in front and 3k in the rear.
Camber is now on -1.5° at the front and -1° at the rear axel. Spur is -2° at the front and +2° rear.
Traction is very good. The new MMX is working very well. I love the new Aux Port at this ESC. It was very Wet when I test it and help a lot to finde a good Set-Up for the punch control.
KMN
KMN's Avatar
02.02.2016, 05:02 PM
If they will fit, I ended up with the Kyosho 74mm Blue's. They're the stiffest they offer for 16mm shocks. I believe they are on par with the HB Orange springs, so either would work. I also ended up going to 47.5wt in the rear and 55wt in the front. The truck hasn't been run yet, but I can drop it from about 4FT without it bottoming out or rebounding too quickly.
Mr E-Maxx
Mr E-Maxx's Avatar
05.27.2016, 04:00 PM
Hi,
I found my Shock Set-Up now. I chose 8 Team C T8 Rear Shocks and limit them in both ways around 5mm. I use red hard Team C Springs and 50 WT Losi Shock Oil. It works very well.
I hope my new Body is reedy soon.
