My Brushless Racer Emaxx Light Weight
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
My Brushless Racer Emaxx Light Weight - 04.12.2006, 09:36 PM
weighs about 9.5 lbs with body on, has very good handling, awsome racing machine
ID:	1071   Click image for larger version
ID:	1072   Click image for larger version
MetalMan
MetalMan's Avatar
04.12.2006, 09:55 PM
That's pretty good, especially considering that you could remove even more weight!
squeeforever
squeeforever's Avatar
04.12.2006, 10:09 PM
really nice truck! yes, metalman is correct. removing 4 shocks, different rims and tires, shifting servo and or single speed conv. could make this truck really light.
luvsrc
luvsrc's Avatar
thanks squee and metal !!!!
luvsrc
luvsrc's Avatar
04.12.2006, 10:13 PM
i do really agree ,what kind of wheels and tires do you guys suggest and will the single speed from gorilla maxx fit into this? the chassis is from extreme racing company any suggestions are welcome and thanks!! can four shocks handle it? what kind of spring ? can i just remove the other four shocks ( i'm currently using big bore shocks) and get a different spring if so where? ( any link?) and links for the tires and wheels as well by the way with the chassis it is 1 inch longer than the stock
squeeforever
04.12.2006, 10:18 PM
yes, the single speed will work. i would go for the proline velocity 40s, dace 23mm hubs, and crime fighter tires. also, 4 shocks can handle it. it just takes heavy duty springs. i used trinitys.
i would try these springs: http://www2.towerhobbies.com/cgi-bin...?&I=LXHWJ7&P=7
run these tires: http://www.rc-monster.com/proddetail...PRO1122&cat=42
these rims: http://www.rc-monster.com/proddetail...2678-02&cat=42
and these hubs: http://www.rc-monster.com/proddetail...03223BK&cat=42
maxxdude1234
maxxdude1234's Avatar
04.13.2006, 03:55 AM
I've got that chassis too luvsrc, it really does handle very well. Definately loose 4 shocks, and get the single speed conversion. It'll make it handle even better.
blackhawk444
04.13.2006, 05:06 AM
How do you like the team orion platinums?
captain harlock
RC-Monster Captain
captain harlock's Avatar
04.13.2006, 05:48 AM
Impressive! you're still using the Hacker car controller?! Can I find one like it in e-bay?
Nice to meet you!
boss 302
04.13.2006, 06:09 AM
looks good how do you like the orion lipos
luvsrc
luvsrc's Avatar
04.13.2006, 05:28 PM
the team orion lipos are everyworth of money, the punch is amazing and the power delivery is a lot smoother than any sub c cells i've used, temps on the whole system motor 108F, controller 104 F, lipos are only 88F , i did run it for about 8 minutes and i know that i can get more run time but the hacker speed controller has no built in cut off voltage can anyone give me a link and info on how to set up a cut off device? it has an actual voltage of 8.26 volts per pack before i started running it. for a total of 16.52 volts, after running it for 8 minutes it still has a total voltage of 15.44 volts amazing!!! can't wait to kick off and eat any nitro on the race track!!!
MetalMan
MetalMan's Avatar
04.13.2006, 06:59 PM
You can use this device as a cutoff:
http://66.241.195.91/lithium/lithium.asp?path1=lithium
It connects to the full voltage of both batteries, and goes inbetween the receiver and the controller's receiver wire.
squeeforever
04.13.2006, 07:14 PM
metalman, what kind of pulse does it give off? a weak or strong motor pulse? if its a weak pulse i would be concerned about not noticing. should this really be a concern?
coolhandcountry
coolhandcountry's Avatar
04.13.2006, 07:21 PM
I think dafni is running this cut off squee.
luvsrc
luvsrc's Avatar
04.13.2006, 09:41 PM
thanks for the link, how to connect the wires to the two packs? any diagram or help is very much appreciated, so it slows down the truck whan the device starts to kick in?
