Apache 3700mah lipos
captain harlock
RC-Monster Captain
captain harlock's Avatar
Apache 3700mah lipos - 06.13.2006, 01:32 PM
What info do you people have on these lipos from Apache?
Mike carries them as you all know, but I want to know how good are they.
Nice to meet you!
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
06.13.2006, 03:01 PM
Not that this answers your question but I'm sure if there were any type of issues or have ever had any bad reports on them, then Mike probably wouldn't cary them. I personly havn't heard anything bad about them.
MetalMan
MetalMan's Avatar
06.13.2006, 04:15 PM
They use the same Enerland cells that Flightpower/Hyperion/Polyquest/Poly RC use.
crazyjr
crazyjr's Avatar
06.13.2006, 07:03 PM
If these are the same as the polyquest "Twenty" cells you just saved me a lot of money:cool: :dft003: :dft008: . please tell me that. Scratch that they are the same price
MetalMan
MetalMan's Avatar
06.13.2006, 09:34 PM
Yep. If you check the dimensions, the differences should all be within about 2mm, depending on the type of packaging around the cells. The same goes for the weights of the packs.
captain harlock
RC-Monster Captain
06.14.2006, 06:41 AM
Is the balancing connector in the Apache pack compatible with the balance port in the Thunder Power charger? Do I have to change them?
Nice to meet you!
MetalMan
MetalMan's Avatar
06.14.2006, 09:17 AM
No, it's not compatible. There are some sites that sell adapters that work with the TP balancers. I am unable to locate a site right now, but when I find one I will post it.
Another option is to cut off the current Polyquest connector and attach a TP connector/wires to it.
