squeeforever
squeeforever's Avatar
08.21.2006, 06:26 PM
Originally Posted by neweuser
Are you sure squee? I could swear my manual said 10 or above?
Your right, it does say 10. I saw somewhere around here that it was 12 :032:.
jimbiss
08.21.2006, 06:46 PM
What do you reccomend for a slipper?
08.21.2006, 07:27 PM
Any cell count above 5 (6v) will create heat on a built-in BEC since they are linear. More cells, more heat. I'd rather use the heatsink on the ESC for the important part, the motor controller, rather than heat it up for the BEC function. I'm only running 6 cells (and 2s2p Lithium) on my Mamba max and I am thinking about getting a BEC since the heatsink on the ESC is so small. Just a little extra insurance. Plus, a digital BEC is more efficient and will help increase runtime (albeit negligible I'm sure).
squeeforever
08.21.2006, 07:31 PM
Go with a Strobe slipper if you can find one.
jimbiss
08.21.2006, 08:13 PM
Any other slippers that will hold up to brushless?
squeeforever
08.21.2006, 08:57 PM
Not really. The Kipster is good but out of production as well and even harder to find. The RRP locked down with a modified Mod1 spur is the next best thing. I would assume you can modify a Ofna spur for the Kipster as well since it uses the RRP spurs.
Tazz
Custom
08.22.2006, 08:06 AM
I believe it is 5mm, but double chekc on the site, that'll tell you foresure. Gearing depends on what your runing it in. if you are running 32 pitch, 12/66 would be a good starting point maybe, or 51 mod 1, 16/51 is a good starting point. But again, all depends on what you're running it in.
Not trying to be picky, but I think that you might have the pinion gear switched around (12/66 - 5.5 ratio, 16/51 - 3.19 ratio)(16/66 - 4.13 ratio, 12/51 - 4.25 ratio).
