7xl/ mamba max!!
phildogg
phildogg's Avatar
7xl/ mamba max!! - 11.24.2006, 05:25 PM
ok went ahead and took the esc out of my rusty to use in the E for a few runs on the 7XL.. ran ok,not alot of speed though.. (this is 12 cells gp3300 )the motor stayed cool 130deg. about 75 outside now. the esc got hot.. 170 deg, but running the bec circuit on MM. ( I figure that was cause of heat.) batts stayed cool 100-110)what does everyone think? I was more speed though.I figure 4s li-po will help,maybe 5s? opinions please.. also gonna get a ubec.. gearing is 18/66 now.. ok to gear up with a ubec?
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
smhertzog
Breaker of all that is Stock
smhertzog's Avatar
11.24.2006, 05:37 PM
You might want to put a fan on the MM if its getting 170 with 3300 nihm. The added amps and longer run times of lipos will get it alot hotter.
Never fight an ugly man..... he has nothing to loose
glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.24.2006, 06:03 PM
Actually the boys at CC say that the more powerful the batteries, the better for the Mamba....
phildogg
phildogg's Avatar
11.24.2006, 06:30 PM
I was thinking that running it with 12cells and no ubec was contributing to the heat also.. what about gearing?
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Serum
Serum's Avatar
11.24.2006, 07:21 PM
get a ubec man..
using 12 cells with a high torque servo is killing for the internal one. it sure will take away some heat. the bec isn't meant for this.
phildogg
phildogg's Avatar
11.25.2006, 03:08 PM
heat prob. solved.. added a receiver pack I already had and a small fan and temps dropped to 100 on the esc.. motor was right around 140(depending on where I took temp from 135-142) alls good now.. thanx bros..phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
Serum
Serum's Avatar
11.25.2006, 03:17 PM
Anytime Phil!
glad to hear the problem is solved.
coolhandcountry
coolhandcountry's Avatar
11.26.2006, 10:06 AM
So what do you think about the 7xl on mamba.
phildogg
phildogg's Avatar
11.28.2006, 07:40 PM
It seems to be fine right now.. in the post above temps dropped alot and all acts fine..I ran it on 1 2s lipo the other day waiting on my 2nd lipo to get here..lol but it still had alot of torque flipped the truck backwards easily with 2s.. not alot of top speed though..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
phildogg
phildogg's Avatar
12.01.2006, 04:39 PM
hey took the truck out today on 4s lipo, man runs great.. still had the stock sliders in center,ripped the rear out...lol anyway love the power.. having some glitching issues though,will apply brakes when it does and flip the truck forward..about to strip the front diff doing this.. think its the radio though stock tc3..lol
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
jhautz
jhautz's Avatar
12.01.2006, 05:22 PM
Turn down the braking power to 25% on the mamba programing. This should help.
to make it...
or break it...
Silent...But Deadly
Finnster
KillaHurtz
Finnster's Avatar
12.01.2006, 05:29 PM
Glad to hear its working well for you. I had the same problem w/ mine on the brakes. You can just turn down brake power (as mentioned) or go into castle link and redraw the brake curve to make it more progressive, as well as a bunch of other tweaks. Same for the throttle as well, help tame the beast a bit and make it more drivable. Before I was flipping either forwards or backwords w/ too much finger action.
The usb setup is really slick. Post a top speed if you can, I'd like to compare it to the 8xl.
phildogg
phildogg's Avatar
12.01.2006, 05:45 PM
don't have anyway of testing speeds now, need another gps..no its not when I hit the brakes the radio glitches and the mamba hits the brakes for me..lol will try adjusting it though..
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
JB3231
JB3231's Avatar
12.01.2006, 08:56 PM
I turned my braking down to 1% and it still flips the truck over forward on the Maxx with the Mamaba ESC. On the opposite side, the 9920 on the LST2 won't seem to add enough braking power. Go figure.
Mine:
2007 Grizzly 700 EPS EFI
Sons:
BL E-Maxx
4S MA 4000 Lipo/MM ESC
Feigao 9XL 22/54 gearing
Gmaxx single speed
Brushless Revo under construction
jhautz
jhautz's Avatar
12.01.2006, 09:35 PM
Thats weird!?!?! Are you adjusting the braking force or the drag brake? Brake force only goes in 10% incremants... 10%, 20% 30%...ETC...
How did you get 1%
Do you have EPA on your radio?
to make it...
or break it...
Silent...But Deadly
