aqwut
Brushless Heavy Weight....
aqwut's Avatar
12.06.2006, 02:19 PM
Single setup is much better IMO..... Havin' dual sounds cool, but you never know when/if the two motors/esc are fighting eachother.....
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
Serum
Serum's Avatar
12.06.2006, 02:41 PM
They are rotating into the same direction, so it's most likely they work together. It doesn't need an accurate timing when you use two motors and two controllers. It takes more care to use two motors on a single controller.
neweuser
neweuser's Avatar
12.06.2006, 04:09 PM
And this would be because each esc is reading A motor, not one esc trying to read two right?:032:
Serum
Serum's Avatar
12.06.2006, 04:35 PM
If you are using 1 esc and two motors, you need the rotors start at an identical time. The esc needs to see the two as one motor only.
Dafni
Dafni's Avatar
12.06.2006, 04:41 PM
For as long as you run both combos on the same battery, you should be fine. (use two Lipo packs in parallel)
neweuser
neweuser's Avatar
12.06.2006, 04:46 PM
Makes sense. Thanks
