RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.25.2005, 11:54 PM
I sell batteries, too! That is a nice conversion, Keith. That motor mount is BEEFY! I see you don't run a receiver pack or UBEC with that. How does the bec in the controller do? I was talking to Alex of BK electronics for a while today and he said it can handle up to 16 cells with one servo! I haven't even tried to use the BEC in my E-maxx on 12 cells. I guess I will try it and see what happens. Nice article on RCU also!
studysession
01.26.2005, 04:55 AM
Thanks man! :) BEC did fine. No worries there.
http://studysession.com
Sponsored by:
http://www.mtroniks.net
http://www.brushless-motor.com
http://www.modelelectronicscorp.com
HotnCold
HotnCold's Avatar
01.26.2005, 07:00 AM
Nice conversion - cant wait to do one myself:)
Hows that "Hope and Change" working out for Ya???
Newbie Question
RacerXredraoB
Newbie Question - 01.31.2005, 07:34 PM
Hello,
I currently have a Sportwerks Mayhem Pro 1/8 scale buggy and I am burned out on nitro racing. After reading some forums it looks like converting to a brushless setup is somewhat easy to do. My questions are:
Do you recommend the Feigao 9L or 10L?
Do you recommend the Warrior 9918?
The next event that I will attend for 1/8 racing will be the Dirt Nitro Challenge in CA.
Will this brushless combination with 12 GP3300 matched cells allow me and more importantly the buggy to keep up with the nitro counterpart?
Is there as much torque as a topend .21 and is the top speed similar to a topend .21 with a brushless system?
What would the runtime be with this setup?
Do you run the batteries in series or parallel?
I read that using a 6v receiver pack will increase the steering servo performance, but add a little additional weight over using a UBEC. Is it recommended to use a receiver pack or UBEC in a 1/8 buggy for racing purposes?
Sorry for all of the questions, I just need to know if the performance of a brushless 1/8 buggy will be equal to a nitro 1/8 buggy before making the large investment.
Thanks,
Damron
Re: Newbie Question
RC-Monster Mike
Site Owner
Re: Newbie Question - 01.31.2005, 08:05 PM
Originally posted by RacerXredraoB
Hello,
Either will work well, depending on the gearing, and either will provide plenty of power.
The 9918 warrior will work fine in this application(as you can see!). The micro 18120 would be a better controller, as it has more adjustability and can handle hotter motors, but the 9918 warrior keeps the cost down.
These converted buggies will run just as fast on the top end and have even more punch on the low end (will out accelerate the nitro buggies). I have beaten nitro buggies in drag races with my e-maxx!
This I can't answer accurately - Hopefully studysession will check in and answer this based on his recent experiences. With gp3300 cells, you can definately finish a 5 minute heat, but a lot depends on the track, the gearing, etc.
Keith: a little help here?
Batteries are run in series, so 14.4 volts.
I am pretty sure Keith (studysession) doesn't use either. The BEC in the controller puts out 5.5 volts, the ubec will put out a consistent 6 volts and the receiver pack will put out slightly more than 6 volts when it peaks, and the voltage will decline throughout the run.
Don't worry about all the questions. That is what these forums are for! Ask away.
Thanks,
Damron [/B][/QUOTE]
By the way, welcome to the site!
RC-Monster Mike
Site Owner
01.31.2005, 08:55 PM
I guess my last post doesn't look so good. I placed the answer in between the quote, so they are hard to read. Fixed.:)
RacerXredraoB
01.31.2005, 10:54 PM
Thank you for the quick answers. Runtime will be a determining factor, since most qualifiers range from 5 to 7 minutes. Then the mains are another issue. A quick change battery system would need to be setup.
Thanks again
RC-Monster Mike
Site Owner
01.31.2005, 11:06 PM
LiPo batteries could also be used to get the runtime up in the 15-20 minute mark, but you are talking some expense there. Not to mention the nitro guys crying about the fact that you don't have to pit! Nimh batts should get you through 7 minutes, especially the new gp3700s when they become available.
HotnCold
HotnCold's Avatar
02.01.2005, 07:27 AM
A quick change battery system would be awesome to come up with - That would take a little thought though.. As for them nitro guys crying about not pitting - we'll wait for them just before the finish line..:)
studysession
02.01.2005, 01:31 PM
I am getting anywhere from 8 - 12 minute runtimes at the moment. There are things I can do to improve but to be honest, I am happy with that right now. I am running 12 cells in a series. A lot of people recommend to use 14 to get more speed out of it. I think it is fast enough with 12 cells and not going to 14 anytime soon.
Hope that helps.
Sponsored by:
joostin420
04.04.2006, 03:41 PM
nice setup :004: what tires are you running?
i just got an Ofna 9.5 pro kit and 9L motor :027: hopefully i will get to it once all of my other projects are completed.
justin
virusss
virusss's Avatar
04.04.2006, 04:53 PM
Nice buggy study,I wanted to ask to you if the pinion it resists on the metal spur,is hardened metal?I must use the spur of plastic otherwise mine pinion ruin easy.
Thanks Ettore
studysession
04.04.2006, 05:01 PM
I have not ran it to much since the article. Just ordered a new 9920 ESC from Mike today and hope it is here before the weekend so I can run it again. or I might put the ESC in my EMaxx and wait on this.
As for wear of the pinion. Yes metal to metal does wear quickly and get expensive. It is worth converting to a plastic center diff.
THANKS
Sponsored by:
coolhandcountry
coolhandcountry's Avatar
04.04.2006, 07:46 PM
Sweet buggy. I don't know how I missed this one.
studysession
04.04.2006, 07:56 PM
Now I just can't wait till I get the new ESC to run this again. I also have a MTroniks Genesis Truck ESC coming. I had one but it was a dud from the beginning so mailing it off for warranty and will use it when it returns.
Sponsored by:
