12.18.2006, 08:38 PM
Squee about the XXL motors? will mike stock them anytime soon? Yea i was thinking about the fiego 7XL, whats the difference between that and the wanderer7xl and rcm heatsink?
also in want to be able to do a whole bash session without any cogging, full backflips without it cogg in the air. *note i can add a fan to my MM if needed. And about the motor, would like if i doesnt make any heat issues.
12.18.2006, 08:41 PM
go 7XL (best bang for the buck) also the quark controller is good as well as the castle creations.
12.18.2006, 08:44 PM
The Wanderer have better bearings than fieagao, but that is a very minimal difference. IMO i just like the looks of the rcm heatsink so id take a wanderer with a xl heatsink. But the best bang for buck is the "C" motor. Looks good too.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
12.18.2006, 08:47 PM
yea i herd lots prefer the feigo C xl these days over the wanderer xl's.
IDK, i do like the rcm heat sink on there makes it look nice but im in for the performace here.
gorilla maxx 360, i know the quark is something to think about BUT, i dont think ill be hungry for more power to feed it with, so about 35MPH should be good for bashing, And + more cells is more weight.
Options
1.the quark is 280$ + 90$-(feigo c XL) =370$
2.mamba is 140$ + 150$-(LMT XXL) =290$
3.mamba is 140$ + 90$-(feigo c XL)= 230$
ill rather take option 3-Or 2
12.18.2006, 08:49 PM
The "C" motors will maybe run 1 maybe 2C cooler than the wanderer with heatsink... No difference there, just my opinion.
Losi 8ight e
12.18.2006, 08:54 PM
yeah, i see what you mean kinda in a pickle.
12.18.2006, 08:57 PM
I think option 3 would be the best for budget, option 2 would be ok to, but a bit higher in price.
Losi 8ight e
12.18.2006, 08:59 PM
Yeah it all depends what kind of budget your on
12.18.2006, 09:04 PM
its better for me to ceep it as low as possible, but if im going to buy something that will give me problems ill rather buy the more better diamond if you know what i mean.
12.18.2006, 09:44 PM
Options
YEAH MAN JUST A SUGGESTION but if your on a tight budget/ or your trying to keep it low i totally agree with you if i was on that budget to i would do the same mamba max and 7XL is perfect for your needs and price:027:
12.18.2006, 09:57 PM
yea thanks for the suggestions guys. 70% done in my research now what spures to put on my C diff? Kyosho 44 or 46. I herd 15 Pinion and start from there? that sonds good scince there 1/8 diffs.
12.18.2006, 10:06 PM
15 or 16...If I were you, I would get 2 of each spur. That way you have a spare, and you have both to play with the gearing some since pinions aren't available in every tooth.
12.18.2006, 10:09 PM
Well, i dont think the spur will make as much of a difference as the pinion would, pretty much going up 1 tooth on the pinion is going down 3-4 teeth on the spur.
Losi 8ight e
12.19.2006, 09:14 AM
OK, so im done..... I think. here is my new list
MM=140$
Feigo C XL=90
ubec=37$
2-mod 1 pitch pinions=22$
2-kyosho spurs 44-46=10$
Total:299$
a couple more quesions, can i get a ubec thats just as good at tower for cheaper? are the fiego motors 4mm shaft?
Linear Mode
