heat shrink ?
t-maxxracer32
t-maxxracer32's Avatar
heat shrink ? - 01.15.2007, 11:12 AM
what kind of heat shrink do i gt to put over my batts?
i broke my 7 cell batt and my g/f dad took it to the base and had some people solder it back together and they also used this awsome heat shrink. ive never seen any this big but it held the pack together perfect!! so where should i get heat shrink like this? or what size is it called?
thanks!
Mike.L
Mike.L's Avatar
01.15.2007, 11:28 AM
you can get battery shrink for about four dollars and you get 2.
here is the 3 and 1/2" 6 cell battery shrink from parma.http://www2.towerhobbies.com/cgi-bin...?&I=LXDA14&P=7
here is a 3" 7 cell battery shrink. also from parma. http://www2.towerhobbies.com/cgi-bin...?&I=LXDA13&P=7
  Send a message via MSN to Mike.L
t-maxxracer32
01.15.2007, 11:36 AM
how thick is that?
i want it to be able to hold up together with my bashing... also i might have the cells be 8 cell so would the 7 cell work?
Mike.L
Mike.L's Avatar
01.15.2007, 11:56 AM
its pritty thick and should be fine. for 8 cell packs you may want to buy a 36" long shrink and cut it to your own sizes.
t-maxxracer32
01.15.2007, 11:59 AM
they sell that on the tower?
couldnt find any
captain harlock
RC-Monster Captain
captain harlock's Avatar
01.15.2007, 12:32 PM
Go to maxamps.com. They have alot of these wraps.
Nice to meet you!
t-maxxracer32
01.15.2007, 01:00 PM
alright cool thanks!
Mike.L
Mike.L's Avatar
01.15.2007, 03:10 PM
just type in "Battery shrink" and it should come up.
offroader
01.18.2007, 12:42 AM
Your LHS should carry shrink wrap for batteries.
neweuser
neweuser's Avatar
01.18.2007, 01:10 PM
Also, it helps to Glue your batts as well, not just shrink wrap them.
offroader
01.18.2007, 02:16 PM
Great idea I never glued my batteries so they're never straight. I'll do that next time. Would you hotmelt them?
neweuser
neweuser's Avatar
01.18.2007, 02:20 PM
no, shoe glue. Put them in a jig, make sure they are straight, glue them, then solder.
shoe goo
http://www2.towerhobbies.com/cgi-bin...&I=LXD193&P=ML
Hot glue would work well if your batts don't get hot or warm, once the batts are pretty warm though, the glue does not keep a strong hold.
01.18.2007, 02:25 PM
The trouble with glueing is if you develop a bad cell, it is harder to replace it. I just use a battery jig to solder the cells. Then use shrinkwrap and it comes out straight every time...
neweuser
neweuser's Avatar
01.18.2007, 02:28 PM
this is true. for me though, if i have one bad cell, i replace them all. I never liked running a newer cell with ones that have already been run for awhile.
01.18.2007, 02:41 PM
That makes sense. But sometimes people have their "bashing packs" where cell-matching is not important. It just means that when the pack dies, there will still be one good cell left. It's not like you're trying to replace a bad cell in a lipo pack where it is much more important to have matching sets, especially if in a parallel group.
