JakeE
03.10.2007, 07:32 PM
Originally Posted by rchippie
Jake your buggy looks AWSOME :004: :004: . Is that a rc- monster center diff mount ?.
Yes it is, Mike does awesome work!
jnev
jnev's Avatar
03.10.2007, 08:38 PM
That thing looks so amazingly nice :004: :004: . The motor mount looks pretty familiar. i think I have seen a couple people now with that same mount. :005:
jhautz
jhautz's Avatar
03.10.2007, 09:15 PM
Very nice job! Looks great.
Lots of battery wire and power poles.:p
to make it...
or break it...
Silent...But Deadly
03.10.2007, 10:08 PM
The mount works great with little (if any) flex. It works, so why re-invent the wheel? :)
MetalMan
MetalMan's Avatar
03.10.2007, 11:47 PM
How is the Sport BEC treating you?
Nice buggy conversion! Are you running a 5s2p setup with the A123 cells?
JakeE
Balancing connectors, I may try to clean them up a little but there may not be much I can do there.
JakeE
03.10.2007, 11:58 PM
Yes, it's a 5S2P A123 pack. So far so good with the SportBEC, it doesn't have a definitive contour so I stuck a piece of velcro on the flattest side and affixed it to the shelf I hung off the center diff mount. Time will tell if a more secure mounting method is required. I don't have any experience with other BEC devices so this may not be anything special but the SportBEC acts as a pass through so no modification to the Mamba Max receiver connector is required.
JakeE
03.11.2007, 11:02 PM
Here's a current/voltage graph of a few speed passes I did today. I should pick up an RPM sensor so I can get an idea of speeds I'm hitting.
MetalMan
MetalMan's Avatar
03.11.2007, 11:08 PM
You're not even beginning to work those batteries :). I'll bet you are getting some pretty good runtime!
JakeE
03.11.2007, 11:10 PM
I was just fooling around outside today in between heats at the carpet track. Won't have a real track to race on for a couple months. The graph above was on dusty asphalt with Pro-Line Road Rages.
Logging Voltage and Current
skeeler
Logging Voltage and Current - 03.12.2007, 10:07 AM
JakeE,
The buggy looks good. I hope I can do as clean a conversion. How are you logging the voltage and current draw? Thanks.
JakeE
03.12.2007, 01:14 PM
Originally Posted by skeeler
JakeE,
Eagle Tree MicroPower: Link
JeffEmbracedDC
JeffEmbracedDC's Avatar
03.13.2007, 09:43 PM
Did he make that mount custom for you? I have a hyper 7 as well and I'm interested in that mount. How much does something like that cost? Thanks.
-J
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
JakeE
03.13.2007, 09:48 PM
Yes, the mount was custom made by Mike. Email him (rcmonstermike A T gmail dot com) if you're interested in having one made.
03.13.2007, 09:57 PM
PM answered JeffEmbracedDC...
And welcome to the forums!
