E-Maxx BL conversion. Easiest option?
E-Maxx Hustler
E-Maxx BL conversion. Easiest option? - 03.15.2007, 11:46 AM
To me the Novak option seems easiest since it is a drop in conversion. If I went with a Lehner or Feigao, is there a lot of customization or "fabbing" that needs to be done to make them work? Do they come with mounting hardware for an E-Maxx? What about the open motor compartment on the tranny?
Cheers,
glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.15.2007, 12:03 PM
Novak is easiest, as it's drop in... and uses standard 1/8" pinions.
Most other brushless motors suited for a maxx use 5mm pinions...
But there are a few out there with 1/8 shafts like the Lehner Basic XLs... which would be much better than a Novak when paired with a MambaMax, for about the same price.
And you CAN get 32p pinions to fit the Feigao etc 5mmm motors.
So I would recomend a Feigao L or XL and a MM for under $250
No fabbing needs to be done with the 'non-novak' systems... the unused motor hole is just covered up with tape, etc.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
E-Maxx Hustler
03.15.2007, 12:18 PM
What is the difference between the L and XL? And there are two different XL's. A 540C XL (Looks like it has a built in Heat Sink), and smooth 540 XL's. I assume a 8 or 9 X or XL is what I want but don't know which one to get. Maybe I should just e-mail customer support.:027:
Cheers,
Finnster
KillaHurtz
Finnster's Avatar
03.15.2007, 12:21 PM
Non-novak systems are not really complicated, and will give you much better performance for the $. The only real difference with a Non-novak is that you need either a Rx pack or external BEC as running the ones built in are meant for lower voltages. You can use the empty motor space to mount such a thing there.
The add. upside is you have a huge range of options in motor choice, however a Mamba Max ran on 14 cells or 4S with a feigao 7XL or 8Xl is a hard combo to beat, and will destroy a novak system in performance.
i would also take the opportunity to also upgrade to a Strobe slipper (you'll kill the stocker) with a much tougher Mod1 pitch spur. Mike has mod1 5mm pinions as well.
Finnster
KillaHurtz
Finnster's Avatar
03.15.2007, 12:27 PM
Cheers,
Its the length of the motor arm and can. L is long and XL is... guess. :)
Generally XL are used as the L cans tend to run hot in large vehicles. 9Ls used to be pretty standard, but now its moves on to XLs for more reliability.
Turns? Depends on what you are going after. Is speed or runtime more important? 7XLs will be fastest,, but run hotter and for less time, 9Xls have long runtimes, but are not as fast, and a 8XL is a good balance of the two.
7XL: mid 40s mph likely
8Xl: low 40s
9Xl: hi 30s-40mph
Rough guestimate which will depend on your batteries, vehicle/tire weight etc of course, but you get the idea.
E-Maxx Hustler
03.15.2007, 12:40 PM
Cool. Thanks, man. Yeah, I think a 35MPH-40MPH Monster truck is fast enough:dft002:
So, based on what you just said, I should probably get an 8XL or 9XL. Although they are out of 8XL's. Also, what is the difference between the 540C and the 540? Both are offered in 8XL. One has a heat sink but the motor itself looks completely different.
Cheers,
glassdoctor
TEAM FUSION
03.15.2007, 12:45 PM
The 540 and 540c are the same motors... except for the case design. The c has the cooling fins.
Some prefer the regular smooth cans used with a separate heatsink. I like the 540c finned can.
Either one will do fine. For an emaxx you might want the smooth can just because the smaller diameter will allow more room for gearing options. Big can motors hit the tranny in the emaxx, limiting gearing options (or you can shave down the fins if needed)
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
Mr.lst
03.15.2007, 01:05 PM
there are brackets that bolt onto the side where you don't have an engine that could be used for a esc mount. I say a thread about it a week ago.
E-Maxx Hustler
03.15.2007, 01:27 PM
Will a Mamba Maxx take two lipo packs? does it have 2 inputs?
glassdoctor
TEAM FUSION
03.15.2007, 01:29 PM
You just use a simple Y adapter or wire it with two plugs if you want to use two packs....
I would link to BrianG's calc page thing to show a diagram but it's not working for me right now... page errors.
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
03.15.2007, 01:54 PM
I'm on the phone with my host as I type this because I can't log in with FTP nor the host's control panel either. :031:
Mr.lst
03.15.2007, 03:10 PM
get him make him pay!:007: :mad:1
