Stock E-Maxx with modiified Slipperential transmission
GriffinRU
Stock E-Maxx with modiified Slipperential transmission - 04.06.2007, 08:53 PM
Stock E-Maxx with modified Mike's slipperential transmission and nice brushed motor.
ID:	2712   Click image for larger version
entjoles
04.06.2007, 08:55 PM
looks great, did you make the motor mount?
GriffinRU
04.06.2007, 09:05 PM
Thank you,
Yes, now I am thinking about making one to mount two small 380-size motors, because with current one smallest pinion for motor in mod1 is 18t and limited by motor diameter. So either go to 32pitch or smaller motors.
But current motor has no trouble to run this.
GorillaMaxx360
GorillaMaxx360's Avatar
04.06.2007, 09:10 PM
looks nice is this possably something that could go into production to use with the stock emaxx chassis
GriffinRU
04.06.2007, 09:22 PM
Well, thats the plan.
It would be a simple kit - new drive shafts and filing chassis a little bit to make room for differential gear.
GorillaMaxx360
04.06.2007, 09:26 PM
about how long untill you are ready to sell them? would you sell them through mike and what would you include
GriffinRU
04.06.2007, 09:39 PM
Once testing done then in couple days. I need to check with Mike first.
Kit will include parts from slipperential transmission and drive shafts with cups.
GorillaMaxx360
04.06.2007, 09:51 PM
so everything needed for it to work(basically just mike slipperential but a different motor mount) also the motor mount is machined right because in the picture it looks molded kind of
_also will it work with all size motors like the neu and feiago motors
1bigemaxx
04.06.2007, 10:05 PM
What type of motor is that?
GriffinRU
04.06.2007, 10:13 PM
Printscreen from CAD drawing, actual part - machined from aluminum.
Any 540-size motor with can diameter 35.8mm will fit. So, any Novak, Feigao 540 and smaller, LMT 19-series and smaller.
NeuMotors 15-series won't fit (with 18t pinion) because motors diameter 39.5mm.
I will check for possible motor and pinion combos later.
GorillaMaxx360
04.06.2007, 10:24 PM
is there anyway using a smaller or bigger pinion i could be a neu 1515 motor to fit. and if not will you be making a different version to accomidate these motors or can you motify the current version to allow these motors to work.
GriffinRU
04.06.2007, 10:29 PM
Brushed motor from Plettenberg-motoren.
It is an old one HP270.
HP290 would be a blast too, but I need to check on dimensions first.
GriffinRU
04.06.2007, 10:54 PM
Neu 1515 will work with current adapter using pinion 22t and Up.
I will work on utilization of smaller pinions later.
TimXLB
04.06.2007, 11:26 PM
GriffinRU:
Hi,
great looking mount. just what I have been looking for. I am going brushless in my E Maxx and was thinking about something like this.
please keep us informed.
Thanks
PROTECT ME FROM THE THINGS I WANT.
THAT WHAT FEEDS ME DESTORYS ME.
MetalMan
MetalMan's Avatar
04.07.2007, 12:57 AM
Are there any problems with the motor mount flexing from the weight of the motor? It looks to me like that could be a problem.
