problem with my quark 80b
stampy
stampy's Avatar
problem with my quark 80b - 04.21.2007, 05:50 PM
Ive had it now for over a year and just the last 2 runs it has started acting up. it starts out fine for like the first 100ft then it slows down, and sometimes stops even with the throttle held down. then once i let off and get back on it it does it again, i cant figure it out:030: . its never thermaled or been hot enough to touch (not even close) there was nothing wrong then this happed, any body have this happen or know the cause?
04.21.2007, 07:14 PM
When something starts acting up with no apparent cause (like heat, smoke, etc), I like to check connectors and wiring. Over time, connectors can get dirty which won't work as well. Also, wires may have broken strands from the constant motion or unplugging/replugging. But first, you might want to try another battery - the one you are using may be getting tired.
stampy
stampy's Avatar
04.21.2007, 10:44 PM
ill check and see but its a new lipo probably only 20 runs on it. ill check it out any way
04.21.2007, 11:00 PM
The lipo should be OK then...
stampy
stampy's Avatar
04.24.2007, 02:47 AM
do you think its a loose connection? cause it slows down before it stops:002: could it be the motor maybe? I hope not cause it has less that 2hours on it and it was in a pretty light rustler when it started doing this. (oh the motor is a lehner xl3600)
stampy
stampy's Avatar
04.27.2007, 03:36 PM
anybody?^
stampy
stampy's Avatar
05.17.2007, 02:04 AM
took the electronics out of its case a while ago and every thing is fine. i don't get whats happening it acts fine for alittle while then it slows down like the battery is dieing, then all i have to do is shut it off with the on and off switch and back on and it runs fine for a bit then does it again wtf!!
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.17.2007, 02:39 AM
:confused:
Couldn't tell you. You should phone S&T and tell them what you are running and maybe they can tell you what's wrong?
stampy
stampy's Avatar
05.17.2007, 02:43 AM
ya i might. but the problem is i didn't buy it from them nor any one connected to them, i got it off ebay brand new. i know sounds bad but ive had it for over a year no problems till now. do you think that will matter?
zeropointbug
Z-Pinch racer
05.17.2007, 03:00 AM
What do you mean not from them? They made the thing. They will service the thing. :032:
