Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Thread Tools Rating: Thread Rating: 2 votes, 1.00 average. Display Modes
Which fegiao did you mean?
supralover72
supralover72's Avatar
Which fegiao did you mean? - 06.03.2007, 12:38 AM
I was told to use the fegiao XL motors for my BL Jammin, but I didn't know which 8xl was meant.
This one:
http://www.rc-monster.com/proddetail...WAND_XL&cat=20
Or this one:
http://www.rc-monster.com/proddetail...540C_XL&cat=20
Thanks a ton.
06.03.2007, 12:41 AM
Either one will work. However, you can use the RCMonster heatsink/clamp to keep the Wanderer's front plate from popping off.
AAngel
06.03.2007, 01:04 AM
The C model does keep a bit cooler, but it has its own problems. I'd go with the wanderer so that you can use the heatsink clamp to keep it from falling apart.
supralover72
06.03.2007, 12:49 PM
Thanks a lot guys. I'll go with the C than.
AAngel
06.03.2007, 04:42 PM
If you do go with the C, be sure to take some measures to be sure that you don't loose the rear endbell.
06.03.2007, 05:13 PM
That's why the smooth can with the RCM heatsink is probably better; the clamp action of the heatsink holds the whole thing together. However, IIRC, MetalMan had his C can come apart and he used JB Weld to glue it back together and it worked fine.
jnev
jnev's Avatar
06.03.2007, 06:16 PM
Can someone explain what IIRC is or what it stands for? I have seen it so many times, but could never figure it out. Sorry for the newbish question.
Thanks.
06.03.2007, 06:31 PM
IIRC = If I Remember Correctly.
Some say "recall" instead of "remember", but it's the same thing.
supralover72
06.03.2007, 06:51 PM
Do I get the L size or the XL size for the clamp heatsink? Thanks.
MetalMan
MetalMan's Avatar
06.03.2007, 07:16 PM
Correct. The Feigao 540C 7XL in my Revo started coming apart at the front endbell, so I took it off, put some JB Weld on, and since then haven't had a problem. I've done some racing and jumping, lots of gnarley crashes and such, but it hasn't budged :).
On the other hand, when the front endbell came apart on my Feigao 540C 9L, it completely destroyed the front bearing, and now I can't get the outer race of the bearing out of the front endbell...
06.03.2007, 07:18 PM
Mike has several verions for S, L, and XL - and a couple of colors too. Just look at the dropdown list for that item
