JatoE -
06.20.2007, 09:28 PM
Here is a conversion I am in the process of on a Jato 3.3. It got old really quick having to tune the nitro motor all of the time so I decided to change over to electric. My plans are to go with a brushless setup with a high Mah Lipo battery I just haven't decided on which ones yet and I also wanted to make sure everything would work before I invested the money. It has the single speed trans so I could have braking without using two servos, a 58t integy spur gear and a 22t robinson racing pinion. I used RC Monster's electric Revo motor mount and had to modify the bottom of the mount with new holes and trim one side wich took about 10 minutes after that it pretty much bolted up. Don't mind how messy it is right now this is just testing with some old parts I had from about ten years ago. Let me know what you thing and if you have any questions let me know. Also if anyone has opinions about what brushless setup to go with or spur and pinion I should try let me know.
