Originally Posted by FLMSavage
ok ok that's not looking too bad. $80 US for one of those 9xl motors is not too bad. I just saw the first page with $280 motors and it kinda scared me a little bit...well, a lot.
What's the difference really? If an $80 will work fine, why get a $280 motor?
Quality of construction & efficiency. feigao type motors are very good value, but they are not as well built as the expensive neus/ lehners etc, and they are not as efficient, meaning they heat up more. Some people occasionaly get a bad motor where the magnet splits too, but it is quite rare.
How much power will the 9xl motor give me? I don't really care a lot about top speed and all that, I care more about accelleration because I just a basher, no racing what so ever (no where to race)..so I'm just messing around in gravel pits and random places I can find.
Do you think the 9xl will give me as much power as my .28 engine?
The power a 9xl will give you is massive, more than any nitro engine could ever manage, both in terms of torque and speed. if you are just after good acceleration and usable topend, then you would gear down a little, or use 12 cells instead of 14.
I'm trying to find an MM speed controller you mentioned. Do you mean Mamba Max? If so I was trying to find one that supported 14 cells but they all said 12 (the ones on the RCM store). Am I missing something here?
The MM (mambamax) is rated at 12 cells yes, but it can easily run 14 cells if you disable the built in bec (this powers the radio and servos). You simple remove the red wire from the rx lead and tape if back onto the other wires, and use your rx pack to power the radio & servos.
Also, what are these lipoly batteries that cost $300+ it seems awfully extreme for just a battery. Why is it so expensive?
Lipo batteries (lithium polymer) are the next generation of batteries, they have a much greater 'energy density', meaning they can hold many more Mah of power than any Nimh or Nicad. They are also much lighter. The downside is the price as you noticed- the better the quality and higher the mah capacity the more $$$ you pay.
And what do the terms "5s1p" and 25C 125A CONTINUOUS, 50C 250 AMP BURSTS mean?. What does the 25C 50C mean?
Basically lipo cells have a voltage of 3.7v, so a '5s' pack is 5 cells in series, giving 18.5v in total. The 'p' stands for parallel, meaning a 1s1p pack is 3.7v & 4000mah for example, a 1s2p pack is 3.7v & 8000mah, and 2s1p is 7.4v & 4000mah, and 2s2p is 7.4v & 8000mah etc etc. The idea is wiring cells in series gives more voltage, but the mah capacity stays the same, but wiring in parallel give the same voltage, but double or triple the mah capacity.
With escs you have 2 ratings normally, continuous and burst. The continuous rating is the amount of amps the esc can supply continously, without buring up. The burst rating is the maximum amount of amps the esc can supply for a short period, usually something like 10 seconds; this is useful because under hard excelleration the motor draws alot more amps from the batteries & through the controller than it does under normal running. For example, just driving along you will draw about 20-30 amps say, but when you nail the throttle from a standstill the motor may draw up to 120-150 amps, but only for a split second or two.
With lipo (and nimh) batteries they generally have 3 ratings; Mah, continuous and burst/peak.
The Mah (milli amp hours) is the packs capacity- the more mah, the longer the batteries will run for (exactly like fuel tank size).
The continuous rating, 25c for example, is how many amps the battery can supply continuously without overheating (puffing in the case of lipos, venting with nimh packs). 1c is equal to the packs capacity, say 4000mah = 4amps, which is 1c. 25c would be 25x4 amps = 100amps. Different packs have different mah capacity, and also different 'c' ratings, again down to quality and intended purpose really.
The burst/peak rating refers to the maximum amount of amps a battery can provide for a short period (10-30 secs depending) before it puffs or vents, and that is rated the same way as the sustained or continuous, say 50c, which for a 4000mah would be 50x4amps=200amps. Again, the motor only draws that much current for a split second so the battery will be fine.
The problem alot of people have is that they get a cheap lipo battery that can only provide a limited number of amps (low c rating), say a 10c 2000mah pack, and when the motor continuously sucks 20-30 amps, the battery cant keep up and so puffs, or bursts into flames (rare, but it does happen with older lipo packs).
For bashing, I think you will be perfectly happy with some good quality Nimh packs, with 4000mah or more- deans plugs are a must though, and side by side packs are better than stick packs if you can help it.
