Yes it is an ofna diff. From an mbx buggy. It uses the same spur as the strobe slipper clutch. Yes they are nubz and I really like them. HPI did a good glue job because they stayed on for all the speed runs an still look great. The nubz are heavy. Here are a few weights.
Nubz 216 grams each
Bowtie,firm foams,veliocity wheel 208 grams each
Traxxas response on revo wheel 192 grams each
The 17mm hubs are from ofna. I've had them for a few years. But Towerhobbies still sells them
http://www2.towerhobbies.com/cgi-bin...?&I=LXXE06&P=7
The 2240 is giving the Kokams a work out but everything seems fine so far. The 2240/10 6s peaked at 110 amps and pulled 70 normal. Peaks watts was 2300. I also tried the 2240/12 with 9s. The watts with this combo peaked at almost 3500.
Thank you,
Promod
