diff oils
dadnjesse
diff oils - 09.15.2007, 08:06 PM
What wieght oils do I need in the front rear and center diffs for a LSP truggy.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.15.2007, 11:37 PM
Well with a center diff it gets tricky. If the oil is to thin you'll just spin your front tires on take off, to thick and you'll be on your roof every time. Front and rear oils can be the same, maybe a little thicker with the rear to help cornering. I can't recommend any specific weights because I have no experience with MT's, center diff's, or 4WD for that matter. Hope this helped a bit.
squeeforever
squeeforever's Avatar
09.16.2007, 02:24 PM
Well, if its brushless, its gonna be alot higher in the center diff, which most nitros usually run around 5-7k. I would suggest buying a small arangement. Usually, the rear is gonna be the thinnest, and the front the thickest, but with BL, the center will probably be. A nitro usually runs around 10-7-5, 7-5-1, etc. I'd say start with 10-30-5.
A4DTM
09.17.2007, 01:42 AM
i've got 50k in the center, and think it suits my power best.
dadnjesse
09.18.2007, 10:29 PM
I ended up using 10k up front, 50k center and 3k in the rear
A4DTM
09.19.2007, 09:45 PM
how do you like it? i've still got stock in front and rear, but my rear needs rebuilding.. do you know what stock oils it had? and how does it compare now?
Sower
Sower's Avatar
09.20.2007, 03:15 PM
My CRT has 7k in the front, 30k in the center, and 3k in the rear. Works awesome for me. Although I can still pull the front tires off the ground on the straight away, so maybe I need to thin the front a little?
waterdog49
Team F.U.B.A.R. Racing
09.20.2007, 04:49 PM
i run 7F/30C/5R in my Losi 8T with Neu 1515 1Y/F on 4s lipo...
Ron
time trials videos...
http://www.rcboatingdistributors.com/SAWVideo.htm
electric truggy conversion pictures...
http://skellyo.com/Ron/
gixxer
gixxer's Avatar
09.20.2007, 04:55 PM
I run 10f/20c/5r in my losi 8t
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
squeeforever
09.20.2007, 11:21 PM
The stock Lsp only has grease.
bdebde
That's All Folks!
bdebde's Avatar
09.21.2007, 10:43 AM
Yah need to thin the center if you're pulling the front end up.
Sower
Sower's Avatar
09.26.2007, 01:03 PM
Actually I'm going to thin everything. My steering isn't as tight as I would like it to be so that should help me there too. I'm thinking 5/10/1 as my f/c/r.
Mike_D
Mike_D's Avatar
09.26.2007, 08:16 PM
I use 7k in the front and rear and 50k in the center. I had good results with a nitro engine so we'll see if it still works fine when i get the brushless stuff in there.
Electric Dave
09.26.2007, 09:30 PM
I've tried to use the various "formula's" out there to predict how my truck will handle with "lighter" here or "heavier" there...in my experience, your truck and driving style are sufficiently different from that of the advice giver that you really have to see for yourself. In my E-CRT, light center oil made the truck very unresponsive. I felt like it allowed too much power to go to wheels which were slipping. The result was a strange acceleration curve and poor steering. When I thickened up to 50K in the center it made a huge difference. Much snappier performance and better, more responsive steering to boot. Not sure I can explain it but I won't go lighter in the Electric CRT. Oddly enough I went from 30K to 10K in my Nitro CRT and prefer the 10K! Same tracks, different power delivery.
DM
09.26.2007, 11:05 PM
Thicker oil in the CD will allow better take-off if you can keep the front on the ground. Thinner oil will help on-power steering a LOT more, but take-off will suffer since the front unloads easier. I would say 30k-50k depending on the weight distribution and how curvy the terrain is.
