Thomas P
09.26.2007, 03:38 PM
Hmmm...that dont sounds soo good :/... how about the GTB ESC then? can that one handle the HV?, or do i need a new ESC?
Maybe il get a MM system? a 4600?
i will use this truck for indoor racing, no rocket is needed...
  Send a message via MSN to Thomas P
Thomas P
09.26.2007, 03:54 PM
maybe this one? the HV 4.5r with a controller? or do i only need the motor, can the GTB handle ?
http://cgi.ebay.com/Novak-HV-High-Vo...ayphotohosting
aidE
09.28.2007, 11:14 AM
Vintage: Then you would prefer the MM 4600 over the 5700? ( I can't make up my mind of which one to buy for my crt .5 conversion.)
09.28.2007, 12:34 PM
I wouldn't use either of those motors. I tried them both and the motor/ESC gets a little too warm for my taste. An 8L 0r 9L motor on 3s would be better IMO. Or even an S motor. The outside dimensions of the MM motors are very close to an S motor, but the S motors have more of the can filled with coil wire so they are stronger. So really, the MM motors are kinda like a sub-S size IMO.
