just finished prototype of center diff for my maxx mounted inside the trannny.
the diff has couple shims and 8x12 bearing on the cup side that goes directly to tranny case. revo axle stub works as output shaft on cup side
e-savage tranny shaft is on the other side as it had holes in right places to make it 40mm long.
bevel gear is secured to the cup directly by two screws and by another two through modified maxx drive dog or modified kyosho spur (just shaved off gears and jbwelded 2 screws to hold 2nd speed gear)
There is again 8x12 bearing inside the gear as it goes over the bevel gear and of course 6x12 outside
I like the kyosho version better but hard to say if those srews will hold.
I still need to clean up the drivedog as jbweld is bit messy to work with
In the worst case I will have the gear holder made from aluminum/steel
If weather allows it i will test it on sunday.
