How do you mount your MGM??
david lamontagn
How do you mount your MGM?? - 11.15.2007, 10:29 PM
Could you tell me how do you install your MGM controler in your truck?
Can i put the heatsink directly on the chassis or should isolated it from the aluminium chassis?
I can see that they have 4 littles thread holes in the heatsink, can i use it to secure the controler to a an aluminium braket??
Or you just sit it flat on the chassis or a braket and use zip-ties to secure it?
Thank you!
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.15.2007, 11:41 PM
I put one of these where the second motor went. Then servo taped and ziptied it. I mounted it side ways with the heat sinks perpendicular to the chassis. I thought I would get better air flow for cooling like that.
david lamontagn
11.15.2007, 11:54 PM
OK thank you! But on my Mugen MBX5, i'll can't use this mount, so i'll simply make an aluminium braket that i'll screw on the center diff plate, and use servo tape and zip-ties.
I've two novak 30mm fan but not sure if i'll install it on my controler. I've the same than yours, a 16018 with a Neu 1515 1Y.
Probably the fan will not be necessary on a 8 lbs buggy
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.15.2007, 11:59 PM
With the voltage and gearing that I am using for about 10 pounds of truck no fans are needed.
david lamontagn
11.16.2007, 12:26 AM
So no fan need for me too. I've a 4s setup with the same controler/motor combo than your's, and i'am gear for about 40m/h.
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.16.2007, 12:32 AM
Me to my motors has never been above 130 and the controller above 120.
11.16.2007, 12:51 AM
Liquid Nail
david lamontagn
11.16.2007, 02:01 AM
James your Avatar is too funny
I'am gone to the bed right now to try it with my wife, good night............................................. .
mkrusedc
NeuMaxx
mkrusedc's Avatar
11.16.2007, 02:30 AM
Umm... liquid nail???
Serum
Serum's Avatar
11.16.2007, 02:34 AM
here is how i mounted mine in the savage..
david lamontagn
11.16.2007, 09:10 AM
Serum, if i'am right, you've use the thread screw in the heatsink to "screw it" on the aluminium plate, right??
And i can see you have the "cube" version.
But your controler is mount in a place where the airflow seam to be very restrictive, you don't have any heat problem?
Thank you!
Kermit MUST be using knee-protection...
I've forget to put mine yesterday......ouch!!!!!!!!!!!!!!!
