Charger charging lead acid 12v battery? -
11.19.2007, 01:58 PM
Hi guys,
I've been looking at an Ansmann xBase charger, and it says on the product description that I can use it to charge a 1-6cell PB (lead) battery, so would I be able to charge a 12 lead acid leisure battery to run the charger when I am at a bash or out for a few hours?
Thanks
Matt
Of course, the battery you use to power the charger will have to have more Ah capacity than whatever battery you are charging, depending on the pack voltage too.
You can use a cheap modded PC power supply if AC is available, or use your car battery as long as you're not charging packs all day.
I forgot about that MAH thing! As the ansmann has a 5amp charge limit. I may end up not bothering, as most bashes I got to there is a power supply there.
lol, that darn mAh thing! To make sure you have a 12v battery large enough, multiply your max pack voltage (4.2v/cell for lipos or ~1.4v/cell for NiMH) by the Ah rating, multiply that by 1.2 (for charger efficiency), then devide that by 12v to get the minimum Ah rating of the 12v battery. So, if charging a 4s 8Ah pack, you need a 12v battery Ah rating that is at least 12Ah.
