11.30.2007, 11:19 PM
Originally Posted by johnrobholmes
Glad to see how well this turned out with the proper rollout. I picked up a 4ft section of L channel today. Time for more "research" into this. Got any taller tires you could throw on your rig to test a higher rollout ratio?
Maybe I missed it, but what ESC did you use in the vid? Sounded like a quark to me.
Did you find it at Lowes?
I would really like for you and the other guys that plan on doing a Direct Drive to Diff conversion to share our findings with each other. I think if we compare notes along the way, we can all learn from it.
In remembering our conversations about Wye and Delta windings, I think you will have a vantage point in building your conversion. I suspect the Wye Termination wound with fewer turns to match the Delta kv rating would work better with this. MUCH more torque.
I tried the Phaltline tires that are 5.5" tall, then I put the E maxx tires on that are 5.75" tall(same as the Revo). They both work well. I don't think I would want to go any higher geared than this.
Even an outrunner needs to spin up a certain degree to make it's power.
With the 5.75" tall tires, roll out is 4.2" per revolution of the motor. Think about that. That's alot.
I think this helps to confirm the statement that "An outrunner motor makes 5 to 7 times the amount of torque as an inrunner does".
Increasing the ratio would just bring back cogging on startup. This cogging could completely be eliminated by the creation of a custom sensor based outrunner setup OR possibly be improved with some internal mods to the ESC. The resistors in the feedback leads could be changed to ones of less resistence.
Most ESC's on the market are designed to work well with a wide variety of motors, inrunners and outrunners alike. I really think startup routines AND Anticipated spool up speed of a motor are based on a curve that is a rough average of how most motors perform. I don't think this "curve" fits every application ideally.
I'm using the 80amp Quark ESC on this right now.
11.30.2007, 11:45 PM
Originally Posted by lincpimp
I guess that I should do some mods to the old direct-to-diff redcat and see what it can do. Need to find a lower kv motor, most likely a 600-650 would do. That will allow me to put some taller tires on it and it will be more off-rad capable.
The main benefit I found was that there was so muck more room on the flat chassis with out the center diff/trans there. Batteries could be placed on either side of the chassis and the balance was great.
Any ideas on a good out runner with 600-650 kv that would run 5s well and have a 5mm shaft? Here is the info on the motor I am currently using, would like to keep the same diameter if possible:
Specifications:
-Rpm(Kv): 833Rpm/V
-Continuous Currect: 50A
-Max Currect: 70A
-Watt: 980W
-Max Eff: 98%
-Recommended Rotor Prop: 8 x 4 to 15 x 8
-Weight: 150g ( Motor Net Weight )
-Total Length: 78.2mm (include Front and Black Shaft)
-Motor Body Diameter: 37.1mm
-Shaft Diameter: 4.98mm(Front and Back)
-Shaft Length: 15.1mm (Front) and 14.2mm (Back)
-Recommended Input Voltage: 8 - 23 Volt
I went back and read over the "red cat" post and studied the pictures a bit more.
Can you get shorter CVD's for that setup?
I'm with John on his recommendation. The Scorpion 3032 motors would work well also. There are two ways to increase starting torque with a motor change. Increase stator diameter OR increase stator length. All the Scorpion 30xx motors use the 5mm shaft.
12.01.2007, 01:41 AM
Thanks for the recomendation. I can always cut and weld my center dog bones to the correct length if needed. A longer stator would be the best bet for this setup as it needs some more torque. Does axi make a similar sized motor to the scorpion 30xx motors? Which scorpion/axi would I want to use? Thanks a bunch for the advise, I have plenty of inrunner experience, but not a wholelot of outrunner testing under my belt!
12.01.2007, 01:46 AM
What does the Redcat weigh?
This motor looks pretty good for the specs you gave.
http://modelmotors.cz/index.php?page...e=12&line=GOLD
That is AXI's website. They make alot of different size motors.
PS. A little off topic, but was there a special bearing that you used on the 1/8th diff pinions? I know you were having trouble getting them to hold up
Reason: PS
12.01.2007, 01:53 AM
Thanks Sike, may have to scare one of those motors up. On the weight issue, the redcat is very light, maybe the weight of a rustler sans motor and esc.
I use the std HB bearings that came with the diffs. I had an issue with a stock revo pinion bearing that the race came apart and the balls made their way into the ring and pinion gears. All of my revos run stock diffs at the moment, I was building a killer maxx / racebomb truck and it is currently in a box at work awaiting time and interest from me!
12.01.2007, 02:29 AM
It's funny you mention the averaging of an ESC startup to fit most motor types. That is how it was described to me by Pat @ Castle. Having different settings for slotted, slotless, and high pole count motors would give the best performance.
Im glad you brought back up Wye vs Delta winding. I need to look back into that. I have an empty 3032 stator sitting here ready to wind.
Lpimp- The 3032 is almost 8 ounces. It will be plenty of motor for most any smaller builds, and very robust from the front ring bearing. Think of the motor weight about the same as an inrunner. You would want 6 ounces of motor for a stampede, so stay with that same heft and maybe add a bit since you will lose gearbox weight. Motor weight is a pretty good indicator of how much power it can produce.
12.01.2007, 02:38 AM
Ok, but I would like to have a lower kv motor, somewhere around 600 - 650kv, so that I can power it with 5s and run taller tires. Not looking to do 70mph, something in the mid 40s with good low speed driveability and less heat production than the current motor.
12.01.2007, 03:13 AM
Choose the 12 turn then, or wind your own for even higher voltage handling. They come in kits too. I don't think changing the Kv will change the max usable height of tire either, only the motor size and voltage used. Time will tell on that though.
http://www.innov8tivedesigns.com/pro...products_id=83
12.01.2007, 11:18 AM
The winding does have alot to do with how much torque she makes.
In comparing this, think about the "turn" ratings on brushed motors. The fewer turns meant you had a high speed motor. If you have many turns, then you have a low speed motor that makes more torque.
A "Race" motor in the 540 size might have as few as 4 turns. But a Lathe motor for a rock crawler might have as many as 30 turns.
Remember the "wrap the wire around the nail" experiment? How did the number of wraps affect amp draw and how strong the magnet became?
Reason: PS I noticed the 4130 starts a little better than the 4120 in this setup on the very same voltage. 660kv versus 305kv
12.01.2007, 11:31 AM
What are you going to use to lock the stator to the bearing holder?
Scorpion uses 30awg wire to wind their motors with. What Ga. wire are you planning to go with?
I've asked some questions and did some research on winding wire size. Lucien told me they use 30awg because it's easier on the workers fingers.
There is only so much room between the stator arms for wire. IMO, a larger wire size might be better. Something like 24 Ga or 22Ga.
If you look at the amp chart for wire sizes. Winding wire is really being pushed to it's limits, but the coating is high temp so it works.
There is an entire science to motor winding. I do want to try it. Maybe get a kit from Lucien, and fix the stator to be removeable. I could wind it, try it, then take it back apart and re-do it. Recording results like this could be very educational.
12.01.2007, 12:56 PM
The reason I say Kv probably won't have an effect on tire size is this: we are working within a fixed stator size and copper saturation for any given motor. Whether it produces 1200 watts with amperage or voltage is up to the wind count and matching voltage. For your nail example, if we fix the weight of wire to wind around the nail we shall get different wind counts based on the AWG used. At least for a fixed voltage, the larger AWG wire will have a stronger magnetic feild.
I do know that kt is directly relational to kv, but as kt goes up the amp draw of the motor goes down too- making torque guessing impossible without actually testing.
Not sure where I am going with this really, I think I have convinced myself that wind count might actually change how hard you can gear the motor  I do know for a fixed voltage a higher turn motor can be geared a bit higher, but that is based on heat and wattage loading of the motor from my understanding.
I ask this: do you think a 10t on 20v or a 5t on 10v would have any startup differences assuming the cells and ESC can deliver the power? In my time I have messed mostly with gearing and voltage and kept wind count constant.
As for building the 3032, I was gonna fix the stator with 30min epoxy or green locktite. The 3032 isn't something I want to take apart multiple times as the ring bearing is pressed in. My plan was to use 24awg wire most likely, I have a 5lb spool of it. Another thing we could mess with is magnet count and arrangement. Probably want to stick with dLRK or 12 slot /16 pole ABCx4 construction for direct drive.
12.01.2007, 01:18 PM
Yes, the larger AWG wire will have a stronger magnetic field because of what? Total Power output as far as watts goes, depends alot on the total resistence of the winding. What affects this? Total wire size used,(multiple strands even), and length of the run.
If you try a Wye Termination winding, just remember total run length is about twice that of the Delta. The thing that intrigues me about it is, it is pulling on 8 magnets at a time instead of 4. This gives a torque bonus at the expense of kv. That's why I was suggesting using fewer turns on each pole.
"I ask this: do you think a 10t on 20v or a 5t on 10v would have any startup differences assuming the cells and ESC can deliver the power?"
I think idealy they would start the same if the strand count was such to make the resistence equal. The 5T would make more heat and draw twice the amps. The 10t would run cooler and be more efficient.
I looked for the Green Loctite at a local "O Reilly" Auto parts store. They had the Permatex brand. Come to find out, Permatex Green isn't exactly the same as the Loctite Green, because it's medium strength. Where can I find the Loctite Green?
I do believe there is a magnet/winding configuration that will work better than these "out of the box" Delta Outrunners. I hope you find it.
12.01.2007, 01:42 PM
I just did a run with 6S1P A123. I forgot to change the low voltage cutout though. With the LVC set at 3.0, the run lasted 11 minutes.
Performance is good. Temps are well in check. The Batteries got up to 120, but the ESC and the Motor remained cool. ESC at 97, Motor at 95 degrees.
A123 with only 1P, the voltage seems to sag ALOT under a load.
I'm gonna try 5S1P 4000mah Lipo next.
12.01.2007, 01:47 PM
I have the permatex green, didn't realize it was medium penetrating. I will probably stick with epoxy then. Only place I know that carries loctite brand would be online retailers.
The conversion from Wye to Delta is 1.7 winds, so a 10 turn Delta is equivalent to a 10/1.7 turn Wye - almost 6 turns. This keeps kv constant. The conversion from a 10 turn D at 980kv to a 6 turn Y is as follows: [10T/1.7=5.88T] [980kv x (5.88T/6T)] = 961kv with a 6T Y termination. Substituting the 6 for any other wind count will give kv with Y termination.
Looks like the 3032 with a 6Y on 4s lipo will be pushing it pretty hard. 15k rpm, don't know how well the ring bearing will take it.
One thing I didn't think of for startup is the length of wire and the inductance on a coil. The ESC will sense a higher strand count coil better, so maybe this could cause lower kv motors to start up better. Not a product of motor torque as much as the ESCs increased ability to see a higher wind motors position? The issue with total motor power always gets me when thinking of startup. To me any 1000watt motor should start up the same unless the wind count is on the extreme end of things. Probably not the most accurate assumption.
12.01.2007, 01:50 PM
Oh yes, the scorpion stators are keyed. If you had the means to mill a keyway into the bearing tube you could easily have a removable stator.
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
