lipo's in series and why one would be different in voltage? -
12.03.2007, 05:38 PM
I have an Emaxx with 2- 7.4v 8000mah in series. Why is it when I do a full run on the batteries and check the voltage with my charger it is different between the 2 batts? one battery is lower than the other? usually by one volt.. Why?
2) The UBEC (if you have one) is only hooked to one pack (instead of across both of them).
EDIT: One more reason I thought of...
3) What do you have your cutoff set for? If it's 3v/cell, then try raising it to 3.1 or 3.2v/cell. Maybe that one pack is just not quite as strong so it dump a bit faster?
Actually, it probably should go into the General Electric section given the topic.
I wouldn't go by any of BrianG's charts since he doesn't know what he is talking about. j/k.
Anyway, then I would say that either one of the cells is a bit weaker and/or the cutoff is a bit too low. Try increasing the cutoff to 3.2v/cell. I assume you balance the packs when you charge them?
Yeah, try and check the voltage with a multi meter at the balancing plug to see if there's one cells that lower than the others. Don't touch the multi meter probes together. 1 full volt is a big difference for lipo.
