Thanks, i will be getting some new shoes for it soon, i used all my $ for a xt8 off ebay, so it will be a little while, but im in MN. so there is snow every where here now and cant bash
i fits ok, but i could have had less issues if i would have mounted the body farther forward, but i wanted the wheel wells to line up as much as possible
the hood scoop made it diff. to mount the front so i added longer body posts all the way around
and yes, it will look much better with truck tires, i may also try a buggy wing mount, the crt positions the wing about 1" back from the rear axle so i would have to cut a huge part of the body out
dont know if it will fit, and if i could get the crt.5 size wing on it, but i will try the one off my truggy when it comes, will more than likely look out of place(size)
RCM Mike uses the normal gt body, so I dont see why the jc one wouldnt work....
Actually, at the bash, Mike had a PL crowd pleaser T4 body(shock tower bumps are in a different location than a rc10gt body). The shock tower bumps in the body lined up so you did not have to cut your body and the wing still fit.
Pic:
Bye
Well, I have a rc10GT CP, and it really doesn't fit(have to cut holes for the shock towers to stick through). Also, the one Mike has in the pic looks different than the one I have too... and yes I'm sure its a CP....
