Here is the new BL ESC in action!!! -
01.08.2008, 10:33 PM
Hi all,
I spoke about this ESC in my other thread and I was finally able to make a video of it in action. The video came out bad and I had to edit some of it off as it was 15 minutes long. I had a problem with my servo getting stuck when I turned to the right. I have the KongPower 2S 5000mAh lipos, Trinity N80 motor and the gearing was set for 3S lipos, so the car is a bit slow. Some folks in another forum keeps saying that when your car rolls backwards and when you try to go forward if it's sensorless it cogs, but this video will prove a lot of people wrong. One guy said that the Tekin R1 does that and I know my MM does it too, but not this controller. Everything was barely warm after 15 minutes and I only put back 2560mAh in the battery. Here is the link: http://www.youtube.com/watch?v=_2uIjw_ct08
Sorry about the video quality and speaking Portuguese.
wow that's smooth. whats the voltage limit? amp rating? and price????
It can handle 4S lipos (16.8 fully charged). It has a AMP rating of 120 continous and 720A burst. I'm still waiting for price from the manufacturer. I also asked them to send me an extra powerboard to see if GriffinRU (Artur) can doulble that up, but I'm not sure if it's needed. I will find out though when I put it in my truck to test it with 4S and see how it pushes the 1521/1Y.
I have to do some more testing to make sure this controller is the real deal. I still have to run it with 3S lipos. The ultimate test will be 4S lipos on my truck and I won't use the fan at all.
looks good for sure.
i didn't know you where really in brasil. we have some brasillians come over sometimes at my work. its amazing the things they wanted to shop for because of the import markups. i was shocked when they told me how much levi pants where. they seemed to really like them though.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
I'm from Brasil. I came to the US when I was 10. Brasil could be a great country if the import duties were lower. Some companies that I know and myself have stopped shipping to Brasil because of that. For example one of my client bought over $7000 of PC parts from me and customs in Brasil wanted them to pay $8600 of duties.
Ok. Here is what I'm going to try next just to see what is the limits of this controller and too see if I can get the overheat protection to kick in. I don't know what the Kv of the Trinity N80, but I might be able to find out with my SPIN-75 and the program box. I threw in my 11.1v 2200mAh pack which has shown bursts of 128A. I kept the 79T spur gear, but changed the pinion from 23T to 30T, because I couldn't find my 32T one. I did a little calculation and it might reach 75MPH. I also took out the foams and added the rubber tires.
Enter Front/Rear Differential Gear Ratio: 2.5
Enter Transmission Gear Ratio: 1
Enter Additional Gear Ratio: 1
Enter Spur Gear tooth count: 79
Enter Pinion Gear tooth count: 30
Enter total battery voltage: 11.1v
Enter kv rating of brushless motor: 6000 (I took a guess)
Enter tire diameter in inches: 2.5
Enter the added radius of tire "ballooning" in inches: 0
Enter Current draw in amps: 50 (I took a guess, I forgot to bring the DPR)
Enter motor resistance in Ω: 0
Spur/Pinion Reduction Ratio: 2.63:1
Total Reduction Ratio: 6.58333:1
Tire Circumference: 7.85 inches (199.49mm)
Total Motor Speed: 66600 RPM
Final Vehicle Speed: 75.24 MPH (120.86km/h)
Effective speed rate: 6.78mph/V (10.89kmh/V)
Calculated Loaded KV value: 6000 (I took a guess)
Calculated motor torque: 0.06 ft-lbs
Calculated final torque: 0.39 ft-lbs
Here are the kv numbers for the N-series trinity's:
N40 6500kv
N60 9000kv
N80 7800kv
I got these numbers in email from Trinity a while back.
Wow. Let me calculate again LOL. I will still use the 30T pinion and hope the motor will handle spinning that high. On 2S lipo it might do 65MPH and on 3S it is up to 97MPH. Thanks for the Kv.
