I am finally getting my E-maxx running again and was checking my controller. Does anybody want to give me advice on what settings to use? Everything is currently adefault setting with the gear ratio 1:1.
I am bashing a:
Neu 1515 1y
50/20 gearing
4s Lipo
FLM E-Maxx
turn the freewheel setting to "on". don't know why they have it off by default. I had to set the brake to the lightest setting, and I turned the accell to .39.
I used the .013 accel setting, freewheel on, auto timing....I have same setup as you, still experimenting with settings ..hey Mkrusedc what lipo you using and what are your runtimes so far?
I use two 2s1p TrakPower Lipo pack wierd in series for 4s. I was going to try and get run times today but ran out of time.
Seriously I think it is around 20 minutes. Next time I get a chance I'll measure for you. There is a thread here that is stickied for run times. Maybe check it for info.
I am using (2) 8000mah 7.4 Maxamp lipos in series, I havent had chance to run long enough to measure my times yet....also been wondering if the single 5000mah lipo will be enough run time for the e-revo would love a 8000mah 5s pack for it, but I bet that will be huge and very heavy...I like maxamps especialy the 3yr/300 warranty, what warranty do the flightpowers and NeuEnergy's have? I know maxamps is not the most powerful though... more middle of road performance vs Neu or flightpower batteries from what I have read
