Well, my old setup works good, but I wanted something simpler. This is about as simple as it gets, barring the outrunner direct to diff setup. I also wanted to try a center diff. I have a Kyosho spur, and a set of the truggy ratio hybrid diffs on order, as well as an 8xl with heatsink, and an assortment of pinions. Everything else is pretty much ready to go.
The Titan is only for mockup
I might also move the position of the ESC, depending on how all the wires fit.
Everything sits really low, yet doesn't hang down too bad.
Even got the skid plate done.
Should balance out real good with a pair of trakpower batteries.
The center skid actually sits up higher than the servo guard.
During the mockup stage.
Using all hardened truggy diffs should pretty much bullet proof my revo driveline. Might have to do something about the center shafts, but will see how they hold up first.
