"Out of spec" enthusiast
01.24.2008, 04:35 PM
Well I have both sensored and sensorless setups (mamba max/fiegao 9l and novak hv4.5) and there is a difference, not just at startup. There is a certain random abruptness I dont like when varying the throttle at 5-20 mph on a sensorless system. For this reason, it doesnt hurt to put some sensorwires in. And it could be both sensored and sensorless simultaneously, which would be ideal.
Soldermaster Extraordinaire
01.24.2008, 05:48 PM
Nice. I know it's been said before, but FINALLY a 5mm shaft for the HV motors! Will there be any other motor kV options for these kits? A good range, I think, would be 2200-3600 kV.
I just finished reading the whole thread. Testing a new ESC and motor winds. Gotcha.
Senior Strategist
01.24.2008, 05:57 PM
Bob Novak comments (from another Forum):
First off I have to say that Novak Electronics is happy to join all you guys out there that think that 1/8 scale Electric Off Road and possible 1/8 On Road racing is the thing of the future. We got into this about two and half years ago converting 1/8 scale nitro buggies to electric as an extremely reliable test bed for our HV Systems. They just ran and ran with very little maintenance. As time went on and more and more racers started doing their own conversions, and not seeing any of the car manufacturers coming out with a purpose built 1/8 electric buggy we decided to get into the conversion business. Our goal was to offer an inexpensive kit, easy to install with very little work or tools, and as good (or better) performance than the existing nitro buggies.
First off a 2 cell 8000mah Lipo should run the same as a 4 cell 4000 mah Lipo. Both have the same amount of energy in them and they both weigh the same. The difference is that the efficiency of a high voltage system is slightly better. Well then why don't we go to a 50 cell Lipo and realy cut down tha losses. It is true that higher voltage gives you more efficiency but then you run into charging and safety issues.
Our testing so far has shown that the electric motor brakes work very well and seem to be preferred by our test drivers. The one thing that electric brakes do is add run time as braking recharges the batteries. This was noticed when mechanical brakes were added and one to two minutes of run time was lost. It is true that mechanical brakes let the motor and speed control run cooler but with proper cooling, this is not a problem. The other factor with mechanical brakes is that it adds almost five ounces of extra weight and about 20% of that is unwanted rotational weight. Run times on our HV System were in the nine to sixteen minutes with a 4s 4000 mah Lipoly battery with various motor winds. This is two to nine minutes longer than a nitro powered buggy.
We found out that the 4.5 turn was almost too much power for our Expert (and I mean Expert) driver and the 6.5 was at, or a little faster, per lap than the nitro version with a $500 Team motor. We also tested a milder wind (7.5 turn) that will be good for beginner drivers and it was only a tenth of a second per lap slower, but very drivable. We also tested a 5.5 turn motor which is just a tad slower than the Neu 1512/1.5 motor which, by the way, is a very good motor. The 5.5 was faster than the 6.5 but run time came down a bit and it was easier to drive than the 4.5T. The choice of motor wind will come down to track size and length of race. Do I smell quick change battery setups?
Our test results on a prop between the Neu and 5.5 HV motors are as follows. This test was done at various voltages with the same propeller:
At 8 volts the Neu turned the prop at 25200 RPM at 44 amps and the HV 5.5 turned the same prop at 23500 RPM at 35 amps. This gives a loaded Kv of 3150 for the Neu and 2938 for the Novak.
Hope this answers most of the questions that you all had. If not ask again and I will try to answer them.
Bob Novak
01.24.2008, 06:41 PM
Wow, Bod Novak really shot my mech brakes in the foot with that testing! Good to see that Novak is testing their equipment and possibly coming out with some more hv options. He is correct about the charging issues with larger cell counts, I personally think that 8s to 10s would be the best bet. Now only if we can get a car esc capable of handling that kind of voltage and offering good brakes. It would be nice to have a sensored controller capable of 5s and a 2200kv motor in a combo.
01.24.2008, 06:46 PM
I have one question/concern about using electric regenerative braking: When braking, is there anything to limit the back-EMF voltage going to the batteries? If not, what effect does this have on lipo cell life since lipos are more voltage sensitive?
All my current setups use electrical braking for simplicity and weight, but this has always been something in the back of my mind...
01.25.2008, 02:32 PM
It sounds like Novak should have a really nice assortment of new HV products for all but the most hardcore speed and power junkies. It's great to know that they are listening to their customers and developing the products that they have been asking for.
I have run a HV 6.5 system in one of my emaxx for the last year or so and it's a great drop in improvement that has proven to be reliable for all round bashing. The only issue that I have with it is the limited gearing range that it is usable without running into thermal issues.
Novaktwo: Can you comment at all on the required gearing for the new HV motors at this time?
03.06.2008, 10:30 PM
Originally Posted by NovakTwo
The new HV esc will be max 6s lipos. After reading these, and ther, forums, I told the engineers that if we couldn't design a new 6 lipo controller to just forget it. Our existing HV products are way overdue for replacement.
any updates on this? if its out soon enough maybe I can just skip the MMM all together.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
03.07.2008, 08:09 AM
I'd be willing to bet that this is waaaaaay down the road. MMM is next month...supposedly.
03.07.2008, 08:15 PM
Yeah but at least we should be able to trade in our current HV escs for the new one. :) ...besides, "next month" when discussing castle products can be "waaaaay" down the road just as well.
03.07.2008, 08:21 PM
Agreed, but at least quote me accurately. My "waaaaaay" has 6 a's.
03.30.2008, 09:38 PM
I'd like to hear an update on the conversion kits. I just checked Novak's web site, and they are still "product not available yet". I'd really like to order one for my OFNA, and hopefully, one that I can put into my Hellfire, since I dont have time to make my own for it (the Revo and my Maxx's take all my time!). They give you the option to "pre-order". I wonder if this means that you put in an order, and they will make them as they are ordered?/?????
