CC MM lights out
phatmonk
RC carbon junkie
phatmonk's Avatar
CC MM lights out - 03.09.2008, 10:56 AM
Hey guys I have 2 MM 1 with bec and run 4s and 3s. on one of them the yellow light went out its 3s and another the green light went out.Allthough they still work fine and calibrate why has this happened and is this something I can fix.
thanks
03.09.2008, 12:23 PM
If it works fine otherwise, it could simply be an issue with the circuit specific to the LED driver (LED itself, current limiting resistor, or IC output driver). I wouldn't worry too much about it, but if other things start going wrong, it could mean a component failure. Either way, it would need warranty work...
