mod 1 spur gear for t-maxx?? -
03.31.2008, 08:22 PM
does any one know where to get a mod 1 72 tooth spur gear for a t-maxx? i heard a mgt spur fits but the largest gear i've seen is a 56
03.31.2008, 10:53 PM
Welcome to RC-M!
A 72t mod1 spur would be HUGE. A 52t mod1 spur is about the same size as a 32p 64t spur (like what's used on the T-Maxx). I've never seen mod1 spurs that could fit a T-Maxx with more than 52 teeth.
Any reason why you need gears with so many teeth? Could you go with a smaller clutch bell instead?
04.01.2008, 06:24 AM
thanks for the welcome metal man i was wondering because i have a few clutch bells left from my revo and was going to use them on my t maxx
04.01.2008, 02:04 PM
actually the size needed is not the 32 pitch tooth count, The 52 tooth MGT gear is about the same size, but not sure of the offset and position to the bell
04.03.2008, 12:54 AM
t-maxx 3.3 or original? the original accepts monster gt spur gears no problem, however, you cut the crank on a t-maxx motor and it won't accept mod1 clutches. What pitch is a revo? I believe mod .8 or 32 pitch, and anyway, a 16 tooth clutch with a 52 tooth spur is about the same as a 20 tooth clutch and a 72 tooth spur(standard t-maxx ratio)
04.03.2008, 01:01 AM
edit- if the revo is mod1 then everything will work, I'm unsure of the pitch though, a 52t mgt spur WILL bolt right up you just need around a 16 tooth clutchbell, can anyone chime in with the revo gear pitch?
04.03.2008, 01:31 AM
revo is mod1
04.03.2008, 04:13 AM
Linc- once again, you da man
Lafayette- it'll all work
04.03.2008, 06:06 AM
thanks guys u were a great help!!
05.26.2008, 04:27 PM
www.hpcgears.com
They have everything you need
Supermaxx
06.02.2008, 09:03 PM
The 52T MGT spur has a diameter of 54mm. It will fit the tmaxx along with the revo cb.
